1.2L Polo 3-cylinder cylinder head cover
chriskross
Post06-12-2013, 17:06    Subject: 1.2L Polo 3-cylinder cylinder head cover Quote
Hello!
I'm currently doing a timing belt replacement on a 2006 Volkswagen Polo 1.2.
I'm currently re-sealing the cylinder head cover. According to VW, you should use the green sealant D154 103 A1. I applied the sealant to the cover, but after about 24 hours, it's still liquid.
How long does it need to cure?
A6 AFB
A6 BRE DPF
Translated on 18-07-2026, 12:22.
Post06-12-2013, 18:38    Subject: 1.2L Polo 3-cylinder cylinder head cover Quote
Hi there,
"24 hours should definitely be enough. Could it be too cold where you are, or is the sealant past its expiration date? Or are only the parts that have been exposed to air still liquid?"
Best regards.
Translated on 18-07-2026, 12:23.
chriskross
Post06-12-2013, 18:42    Subject: 1.2L Polo 3-cylinder cylinder head cover Quote
It's probably around 10-15 degrees Celsius here.
The packaging indicates that it is usable until 07/14.
I'll wait until Monday; I hope it will be dry then.
Do you also use the green sealant to seal the control unit housing?
A6 AFB
A6 BRE DPF
Translated on 18-07-2026, 12:24.
Post06-12-2013, 18:49    Subject: 1.2L Polo 3-cylinder cylinder head cover Quote
The sealant should be suitable. It cures on metal when exposed to air, i.e., after assembly. Perhaps only the excess material is still liquid?
Translated on 18-07-2026, 12:25.
Post06-12-2013, 19:24    Subject: 1.2L Polo 3-cylinder cylinder head cover Quote
The sealant should be suitable. It cures on metal when exposed to air, i.e., after assembly. Perhaps only the residue is still liquid?
Absolutely, the vehicle is ready to operate immediately after assembly. It only becomes hard on the outside after days or weeks.
chriskross
Post06-12-2013, 20:18    Subject: 1.2L Polo 3-cylinder cylinder head cover Quote
Yes, exactly. I mean the residual sealant, which is still liquid.
I'm relieved to hear that; it probably explains the price of a tube! icon_lol.gif
Thank you!!
A6 AFB
A6 BRE DPF
Translated on 18-07-2026, 12:26.
Styrian
Post07-12-2013, 11:03    Subject: 1.2L Polo 3-cylinder cylinder head cover Quote
"...just for reference: How much does a tube cost? How much product is inside? And is it the same as the Elring AFD 2018 (which is red)? That one is listed as an OEM part."
...somehow, I found the older seals more appealing...just my opinion...
Best regards, Styrian.
Translated on 18-07-2026, 12:27.
chriskross
Post07-12-2013, 11:41    Subject: 1.2L Polo 3-cylinder cylinder head cover Quote
The tube containing 100g costs €50.
According to VW, there is a different sealant for the control unit housing, costing €25, which will likely be purple icon_surprised.gif.
A6 AFB
A6 BRE DPF
Translated on 18-07-2026, 12:28.
Styrian
Post09-12-2013, 11:39    Subject: 1.2L Polo 3-cylinder cylinder head cover Quote
...where money can be made...at least, thank you for the information...
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Combo Instrument Cluster, 10.99-09.2001 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Polo: Cylinder Head Torque Specs & Data Diesel Engine Technology
No new posts BBM 3-Cylinder Engine: 44kW Power Gasoline Engine Technology
No new posts Cylinder head cover leak AMF Diesel Engine Technology
No new posts Motoröl in der Zylinderkopfhaube am Injektor Diesel Engine Technology
