Spark plug connectors keep coming loose
denis76
1997 Audi A4 Avant
Post19-12-2013, 17:13    Subject: Spark plug connectors keep coming loose Quote
"On my 1997 A4 Avant with a 1.9 TDI 81kw (AFN) engine, the glow plug connectors keep coming loose."
Due to age, the rubber casing has detached from all 4 connectors.
Is there now a solution for how to replace the connectors individually?
Is there a way to securely attach the connectors to the spark plugs, or to enlarge the contact area on the spark plugs using crimp ferrules?
Greetings, Denis.
 Defekter Glühkerzen-Stecker
 File name:  Stecker Glühkerze.jpg
 File size:  2.38 MB
 Downloaded:  2062 times
Post19-12-2013, 17:24    Subject: Spark plug connectors keep coming loose Quote
Have you ever tried using a water pump pliers to slightly narrow the connector all around?
There's not much you can mess up if you're planning to replace them anyway.
denis76
1997 Audi A4 Avant
Post19-12-2013, 18:06    Subject: Spark plug connectors keep coming loose Quote
No, I haven't tried that yet, but since it's plastic, I assume that it will break, and then I won't have a plug at all icon_sad.gif.
I'm not going to bother renewing it, because the way things are now, this isn't meant to be a permanent solution. I'll have to check on it every two days and make sure all the plugs are still connected. "Where the front and back are usually completely gone."
Post19-12-2013, 19:17    Subject: Spark plug connectors keep coming loose Quote
Look over there.
/viewtopic.php?t=22595&highlight=443+971+994
or there
/viewtopic.php?t=22531&highlight=443+971+994
No new posts Audi A8: Brake Pad Wear Indicator Light On? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Airbag warning light is constantly ill... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Spark plug firing order Technical Data
No new posts Passat 1996: Engine Stalling - Troubleshooting Diesel Engine Technology
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts OBD2 Connector: Types, Uses & Benefits Diesel Engine Technology
