AdBlue Check: 1050 km Range
PAOKGREEK
Post17-12-2013, 18:53    Subject: AdBlue Check: 1050 km Range Quote
Hello, now that the warranty has expired, the problems are starting to appear.
Passat Blue TDI, manufactured in 2009.
I drove to work in the morning, and then I received a message saying "Check AdBlue, 1050km remaining."
The next day, she was gone again, and then she reappeared on the 3rd.
I refilled the AdBlue in the summer.
According to what I've read in forums, the pump needs to be replaced.
"Even the NOx sensor and control units were replaced as a precaution, etc."
Has anyone had any experience with this? Or is it still possible to repair or inspect something?
Is Bosch service competent enough, or is "Freundliche" (a presumably local competitor) a better option?
I inquired directly with the VW dealer, but they need to consult with their technical department because they haven't encountered any AdBlue issues before.
Chris.
Address 01: Engine (CBA)
Label file: RKS\03L-906-022-CBA.clb
Part number SW: 03L 906 022 EN, HW: 03L 907 309 A.
Part: R4 2.0L EDC G000SG 4518
Revision: 21H21--- Serial Number:
Encoding: 0000072
"One error found:"
008424 - Reducing agent.
P20E8 - 000 - Low pressure.
Environmental conditions:
Error status: 01100000
Error priority: 2
Error frequency: 2.
Mileage: 81791 km
Time: 0.
Date: 2112.14.28
Time: 06:39:37
Speed: 1219 RPM
Last: 78.4%
Voltage: 14.06 V
Temperature: 2.7°C
3.4 bar
Temperature: 3.6°C
Last: 70.6%
Translated on 31-08-2026, 20:42.
No new posts Adblue System Malfunction – No Error Code or 28653 / P204F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting the Adblue Warning Threshold with VCDS On-Board Diagnostics (OBD)
No new posts How to check the GRA function? Diesel Engine Technology
No new posts Check DPF fill level Diesel Engine Technology
No new posts Check VP37 Diesel Engine Technology
