Faulty Glow Plugs: Causes & Solutions
tdi-seppl
Post19-02-2018, 18:58    Subject: Faulty Glow Plugs: Causes & Solutions Quote
hello,
"In my Audi A4 B8 2.0 TDI CR, all the glow plugs are defective. There's a constant voltage of 11.9 volts at the connector on the glow plug cables, even when the Audi is turned off. However, the glow plugs themselves require only 4.4 volts. Where is this high voltage coming from? Is the control unit defective?"
Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 30-08-2026, 11:41.
Post19-02-2018, 19:36    Subject: Faulty Glow Plugs: Causes & Solutions Quote
Constantly, i.e., even with a warm engine?
Do you ever get a car scan done?
Translated on 30-08-2026, 11:42.
tdi-seppl
Post19-02-2018, 21:26    Subject: Faulty Glow Plugs: Causes & Solutions Quote
"Yes, even if the engine is warm, unfortunately, I don't have a VCDS."
Post19-02-2018, 21:34    Subject: Faulty Glow Plugs: Causes & Solutions Quote
That would be useful here!
No new posts P0380 Error: Glow Plug System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0674: Glow Plug Circuit Fault, Cylinder 4 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interesting for all Passat owners from 1996 onwards. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPP 2.7 TDI 6 Glow Plugs Defective? Diesel Engine Technology
No new posts BLS Power Rail Glow Plugs: Repair & Replacement Diesel Engine Technology
No new posts Flexible pipe broken again! Should all engine mounts be r... Transmission, Chassis, Body & Interior
No new posts STG Glitches Every 3 Minutes Diesel Engine Technology
