Golfmann Guest
10-06-2003, 20:26 Subject: Build your own cruise control? |
Hello everyone.
'Today I was wondering if it's possible to build a cruise control system yourself. In my Golf 3 AFN TDI, I think everything should be there except the cruise control lever. I read somewhere that you just need to replace the gear stick and plug a three-pin connector into the steering column.' Then, one should be able to build a cruise control system themselves using a button or switch, and activate it using VAG Com.
Do you know what I mean?
I would be grateful for any tips.
Ralf |
Joined: 04/12/2002 Posts: 4742 Karma: +107 / -0 Location: Hagen
10-06-2003, 20:29 Subject: Build your own cruise control? |
Try using the search function. It's actually exactly as you described, and it's even cheaper if you build the switch yourself.
With the search function, you should even be able to find links to installation guides.
Jan. 1Z5 CFHF  / AHB H4D  |
Golfmann Guest
10-06-2003, 21:09 Subject: Build your own cruise control? |
Thanks for the tip, Jan.
I also found something. It's very unclear to me.
Hasn't someone already done this before, and can someone explain it to me in German  ?
It shouldn't be that difficult, really!
Thank you. |
KombiBlue Blaumann
Joined: 04/18/2003 Posts: 76 Karma: +7 / -0 Location: D-48165 Münster
CAN Support
10-06-2003, 21:15 Subject: Build your own cruise control? |
Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB |
Golfmann Guest
10-06-2003, 21:28 Subject: Build your own cruise control? |
Thank you, that's exactly what I was looking for.
I also prefer the original version. However, it is also more expensive and more complicated to install.
Maybe later.
See you later.
Ralf. |
KombiBlue Blaumann
CAN Support
10-06-2003, 21:39 Subject: Build your own cruise control? |
You're welcome!
That's what we're here for!    Gruss Ralf
kapernaum Guest
11-06-2003, 9:16 Subject: Build your own cruise control? |
Hello Golfman!
I also built the cruise control system myself for my Golf III AHU.
However, I didn't install the switches next to the radio as shown here (http://www.tdi-umbau.de/Technik/Tempomat/tempomat.htm), but instead used microswitches directly inside the turn signal lever. The turn signal lever is split at the end and clipped together, which makes it relatively easy to install the switches.
However, running the wires from the turn signal lever to the steering column is a bit tricky, as there's only a small opening there for the cables. I used computer ribbon cable (with the individual wires separated) and ran that through, and it worked perfectly! I've been using this setup for over 2 years and it's been working well.
After a break-in, my car was damaged, with the dashboard and other parts destroyed, costing almost 5000 DM. Additionally, my turn signal was broken. I've been using the original VAG cruise control system for about a year now, but I don't really like it. I find the arrangement of the buttons impractical and not very ergonomic, and it's also outrageously expensive at 68 euros.
If you feel like it, take a picture of your steering wheel and send it to me. Then I can show you where I installed the switches, or explain the details. It's easier to do that with a picture.
P.S. The flat connector for the cruise control module has 4 wires (the part number for mine is 191972704) - to help with your search!
Best regards, |
Golfmann Guest
11-06-2003, 20:48 Subject: Build your own cruise control? |
Well, that's certainly quite informative. Thank you!
I'll take a picture and email it to you.
Where did you find the original plug? Is it on the steering column, or like for others, behind the pedals, hidden under the carpet?
Ralf |
edward Guest
11-06-2003, 21:39 Subject: Build your own cruise control? |
Do the cables in the 1Z wiring harness used in the Audi B4 have the same color coding as those used in the VW? Could not find anything corresponding to that in the circuit diagram!
Is the GRA (Gravitational Roll Angle) only integrated into the electronics if the vehicle is equipped with Autocheck? |
kapernaum Guest
12-06-2003, 10:24 Subject: Build your own cruise control? |
Hi!
The plug is located (as far as I remember) behind the pedals, between the cable bundles from the fuse box and the black foam mat/perforated plastic cover (I don't know how else to describe it, it's a type of plastic with holes, like a shopping basket).
Best regards, |
Golfmann Guest
12-06-2003, 19:26 Subject: Build your own cruise control? |
Thank you, I think I understand what you mean. I've held that many times before.
I'll look into it and report back.
Ralf |
