Fabia: High Boost Pressure - Troubleshooting
chriskross
Post16-05-2014, 20:31    Subject: Fabia: High Boost Pressure - Troubleshooting Quote
Hello!
I'm having the same problem again with exceeding the boost pressure.
The VTG (vertical travel gauge) is movable, and even in its default position, the rod moves up and down without getting stuck.
Vacuum hoses have been checked, and the N75 valve has already been replaced.
A few weeks ago, the boost pressure was too low during the FSP (Flexible Service Package) test, and the N75 valve was replaced as a result.
The boost pressure is too high now.
I recorded data where the boost pressure reached 2500, after which the car went into limp mode.
LMM reaches 1000 when running at full load.
Here are the logs. What I notice is that the EGR valve is operating well above its target value when the boost pressure is above the maximum. Is this normal? Is this controlled by the EDC as a protective measure? Otherwise, I might need to temporarily disable the EGR valve for testing.
The problem occurs in 4th gear when accelerating from a low RPM with full throttle!
Fehler.CSV
 File name:  Fehler.CSV
 File size:  14.65 KB
 Downloaded:  521 times
A6 AFB
A6 BRE DPF
Translated on 28-10-2026, 15:26.
Post16-05-2014, 20:52    Subject: Fabia: High Boost Pressure - Troubleshooting Quote
The VTG is movable, and even with the default setting, the rod moves up and down without getting stuck.
Sorry, but it looks like the VTG is stuck.
Unfortunately, the default setting only indicates that the VTG (Variable Transmission Gear) functions correctly when the vehicle is stationary and at low temperatures. However, significantly higher temperatures are present during operation.
That's why it's often referred to as a "hot connector."
If you're unsure, you can connect a vacuum gauge between the U-hose and the N75 valve and compare the vacuum behavior with the N75 valve.
Look here:
Translated on 28-10-2026, 15:28.
chriskross
Post16-05-2014, 21:19    Subject: Fabia: High Boost Pressure - Troubleshooting Quote
ok, thanks!!
Does this 3-piece cleaning set from In#### actually work?
The studs on the exhaust manifold don't look so good anymore. icon_confused.gif
A6 AFB
A6 BRE DPF
Translated on 28-10-2026, 15:30.
Post17-05-2014, 10:05    Subject: Fabia: High Boost Pressure - Troubleshooting Quote
Autoservice wrote:
Unfortunately, the default setting only indicates that the VTG (Valve Train Gear) functions correctly when stationary at low temperatures. However, during operation, significantly higher temperatures are present.
In addition, the VTG is operated in the default setting with maximum control forces (100 or 0% vacuum). This is essentially like using a crowbar, which easily overcomes light to moderate obstructions.
During operation, even when precise adjustments are required and the adjustment forces are correspondingly low, it can still jam.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post17-05-2014, 10:24    Subject: Fabia: High Boost Pressure - Troubleshooting Quote
My VTG (vertical travel gauge) was also quite smooth after the first repair.
The problem was that it didn't reach the target pressure, resulting in a) excessive boost pressure and b) a significant overboost to 2500 mbar under full load.
Try unscrewing the lid and moving the whole thing with your hands.
Translated on 28-10-2026, 15:31.
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3366 - System pressure (gas): too high Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0402 Error: EGR Flow Too High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fabia RS LD too high (Boon) Upload
No new posts Boost Pressure at 10 Ct on ESP - Too High? Diesel Engine Technology
No new posts AFN: High Boost Pressure - Troubleshooting On-Board Diagnostics (OBD)
No new posts High Boost Pressure, ASZ Engine Diesel Engine Technology
