Audi A3 AC Not Working: 8P BKD Repair Guide
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
georgmech
Post28-04-2014, 15:33    Subject: Audi A3 AC Not Working: 8P BKD Repair Guide Quote
I'm having a problem with my Audi A3 8P. The air conditioning isn't working, and the display is showing -4 degrees Celsius.
The average outdoor temperature is also - degrees Celsius. The outdoor temperature sensor has already been replaced and is working correctly.
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Translated on 09-08-2026, 13:48.
Back to top Profile PM Email
Post28-04-2014, 15:45    Subject: Audi A3 AC Not Working: 8P BKD Repair Guide Quote
Please check all temperatures using VCDS and post the readings. Also, please verify the supply voltage.
Translated on 09-08-2026, 13:49.
georgmech
Post30-04-2014, 12:39    Subject: Antennas: How They Work and Their Uses Quote
"Thank you very much, the climate control is working again. I replaced all three sensors, then drove for about half an hour based on a recommendation from an Audi dealership, and sure enough, everything is working properly again. I'm just curious why that fixed it."
Post30-04-2014, 13:03    Subject: Audi A3 AC Not Working: 8P BKD Repair Guide Quote
I would only be interested in knowing why.
- One of the sensors likely provided readings that prevented the cooling system from turning on.
- Possible time required for the control unit (STG) to calibrate/learn the new sensors.
Translated on 09-08-2026, 13:50.
No new posts Doku Golf 1J bis 01/99, Klimaanlage zeitweise keine Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Function and components of an air conditioning system Technical Articles
No new posts A3 8P1 AC Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Broken AC: Troubleshooting & Repair Tips Transmission, Chassis, Body & Interior
No new posts Tiguan 5N air conditioning system not working Transmission, Chassis, Body & Interior
No new posts Manuelle Klimaanlage ohne Funktion Transmission, Chassis, Body & Interior
No new posts Nachrüstung GRA - keine Funktion On-Board Diagnostics (OBD)
