Polo 86c, year of manufacture 1992
F B
Post07-04-2014, 12:49    Subject: Polo 86c, year of manufacture 1992 Quote
Hi.
I have the car mentioned above, and I'd like to know what kind of information can be read out from it.
With a dual connector and a K409 sensor connected via a serial cable, I can display the lambda sensor reading as the only data point.
Is there anything else I can do, or have I already extracted the maximum potential?
Best regards, Frank.
Translated on 09-07-2026, 9:41.
Karma: +590 / -0   Thank you, like it!
Post07-04-2014, 20:07    Subject: Polo 86c, year of manufacture 1992 Quote
Hi!
Well, I'm quite sure there's more potential.
You should try Googling it if no one knows the answer.
Translated on 09-07-2026, 9:42.
Post08-04-2014, 12:44    Subject: Polo 86c, year of manufacture 1992 Quote
The part number for the engine control unit would be helpful.
F B
Post05-05-2014, 19:10    Subject: Polo 86c, year of manufacture 1992 Quote
Hi.
Sorry for the late reply, but I was first sick, and then the computer stopped working.
The only number that appears is: 030 906 026 B.
Post05-05-2014, 19:15    Subject: Polo 86c, year of manufacture 1992 Quote
This engine control unit only provides measurement block 0, which includes values for the oxygen sensor, altitude correction, and throttle valve.
Translated on 09-07-2026, 9:43.
F B
Post05-05-2014, 19:30    Subject: Polo 86c, year of manufacture 1992 Quote
Sure, no problem.
So far, I can only clear the occasional error code related to the oxygen sensor.
Otherwise, nothing is displayed.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo 9N, Vibrationen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Polo TDI: Specs, Features, & More Diesel Engine Technology
No new posts Polo 6R On-Board Diagnostics (OBD)
No new posts Polo TDI: Specs, Problems, & Common Issues Diesel Engine Technology
No new posts Oil Level Sensor for VW Polo 9N On-Board Diagnostics (OBD)
