Broken sun visor clip for Audi, Seat, Skoda, VW (Solution)
Karma: +807 / -0   Thank you, like it!
Post18-11-2016, 15:25    Subject: Broken sun visor clip for Audi, Seat, Skoda, VW Quote
The clip for the sun visor (sun visor clip, sun visor holder) in Audi, Seat, Skoda, and VW vehicles often breaks even without any external force.
Here's how to remove and replace the sun visor clip:
- Using a flathead screwdriver or a right-angle tool, alternately lift and remove the mounting frame of the clip from the front and back.
- The mounting bracket secures the actual sun visor clip using the two expansion pins. After removing the mounting bracket, the sun visor clip can be easily pulled out of the mounting holes.
The clips and frames are available in colors that match the interior design.
Example of a sun visor clip for Audi A3 8PA, part number 8E0 857 562 A.
The mounting bracket (which usually does not need to be replaced as it is reusable) has the part number 8E0 857 563 A.
P.S.: Attempts to repair it with super glue are not effective. "Clip copies" are available from East Asia, and they are very cheap compared to the original, but you need to be patient.
 File size:  355.77 KB
 Viewed:  1003 times
 File size:  343.52 KB
 Viewed:  1687 times
Translated on 04-07-2026, 3:31.
Ratings - Broken sun visor clip for Audi, Seat, Skoda, VW
No new posts Audi A4 Serpentine Belt Tensioner Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary heater Audi, Seat, Volkswagen, unlock, error co... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2003, broken rear spoiler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Diagnosis: Seat, VW, Audi, Skoda Diesel Engine Technology
No new posts OBD2 Calibration ID for New Audi, Seat, Skoda, VW Cars On-Board Diagnostics (OBD)
No new posts Erwin online store for Audi, VW, Skoda, etc. Dieselschrauber Bar
No new posts Broken 1.9 TDI AFN Camshaft: Causes & Fixes Diesel Engine Technology
