Airbag control unit
Gregor-Pretterhofer
2003 Volkswagen Bora Consumption
Post24-06-2014, 2:08    Subject: Airbag control unit Quote
Hello everyone.
Since the control unit in my Polo 6N2 Gti was damaged when the error memory was cleared, a new one has now been installed by the dealer.
The problem now is that they are unable to get it to compile. I watched them today and I'm not sure if they are making a mistake.
Do you need to enter a login code and then proceed with the coding process to reprogram the control unit? Or is just going to a coding session enough?
Best regards, Gregor
No new posts Airbagsteuergerät Transmission, Chassis, Body & Interior
No new posts VAG-COM: Airbag Control Unit Diagnostics Diesel Engine Technology
No new posts Defective Airbag Control Unit: Causes & Fixes On-Board Diagnostics (OBD)
No new posts Airbag control unit, Passat 3B Gasoline Engine Technology
