Seat Alhambra: Sliding Door Auto Close Coding
TalosXI
Post12-07-2014, 20:00    Subject: Seat Alhambra: Sliding Door Auto Close Coding Quote
Hello everyone,
I retrofitted the power assist feature for the right sliding door on my Alhambra 7N, which was manufactured in 2014.
Unfortunately, I'm having trouble with the coding. In VCDS 12.12.2, there's no information available on which byte needs to be changed to enable the "power window assist" option.
It concerns the STG 72 "Rear sliding door, right side" - part number HW 7N0 959 794 G.
Here's the cropped scan.
Can someone help me?
Thank you very much, and best regards.
Talos.
Scan Alhambra 7N VSSZZZ7NZEVxxxxxx.txt
 File name:  Scan Alhambra 7N VSSZZZ7NZEVxxxxxx.txt
 File size:  2.2 KB
 Downloaded:  537 times
Translated on 19-09-2026, 1:10.
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Alhambra Decoding: Restore Your Data Now! On-Board Diagnostics (OBD)
No new posts Seat Alhambra 2.0 TDI constantly regenerating Diesel Engine Technology
No new posts Problems with Micro-Can on Seat Alhambra On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Seat Alhambra, MSG disabled (RESOLVED) On-Board Diagnostics (OBD)
