Charging control is acting up
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +590 / -0   Thank you, like it!
Post21-09-2014, 18:56    Subject: Charging control is acting up Quote
Hello!
I need some advice about my T4:
2.5 TDI, ACV engine, 2001.
It's weird again.
During the drive, the charging indicator flickered, then turned on, hesitated for a moment, and now it's constantly lit.
I checked the battery a little while ago, and it's fully charged.
The drive belt is okay.
The Lima is electrically functional and has full power.
Okay, so, if the engine is idling with the lights on, it's still showing just above 14V.
The thin, blue cable from the alternator is properly connected and normally disappears into the wiring harness.
I just removed the alternator; it's a Bosch replacement alternator, 90A.
Although it seems like it hasn't been used much, the brushes and carbon contacts are still in very good condition.
Here's what happens without a bra:
If I only turn on the ignition, the indicator light illuminates with very low brightness, which would likely be difficult to see in bright daylight.
After 5 seconds, a relay switches somewhere in or behind the dashboard, and then the indicator light becomes slightly brighter.
Maybe about half the normal brightness.
Well, what's this now?
Does anyone have any ideas about what to do next?
without wasting money on pointless things?
Translated on 07-07-2026, 5:18.
DieselBär30x
Avatar-DieselBär30x
Post21-09-2014, 19:17    Subject: Charging control is acting up Quote
Hi G.Steffen!
The charging indicator light MUST be definitely off when the alternator is disconnected.
I would start by checking the (engine) wiring harness for any signs of chafing. Check out the mass.
I once had a similar problem with another vehicle, maybe this will help you understand.
[url]/viewtopic.php?t=25403&highlight=charging light fabia[/url]
Best regards from Munich!
Translated on 07-07-2026, 5:20.
Post21-09-2014, 23:19    Subject: Charging control is acting up Quote
The thin, blue cable of the alternator is properly connected, and normally disappears within the wiring harness.
I would first try to determine whether the fault lies with the alternator itself or with the vehicle's electrical system.
The check lamp is located between the DF (Defektanzeige - fault indicator) and B+ (battery positive) terminals. It should illuminate when the engine is running. In its operating state, it should extinguish.
The flickering without the limiter might also be related to the open DF line. When connecting the positive terminal (B+), the indicator should turn off.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 07-07-2026, 5:21.
Post22-09-2014, 7:35    Subject: Re: Charging control is acting strangely Quote
Perhaps about half the normal brightness.
Based on the vehicle's year of manufacture, I'm now assuming the traditional wiring of the indicator light (warning light) without a body control module: in that case, when the alternator is connected, no current should flow through the indicator light.
If it's still illuminated, then the cause, in my opinion, can only be due to leakage currents – meaning damp or corroded connectors, or damaged insulation on the excitation cable somewhere between the ignition coil (LKL) and the alternator connector (LiMa). Have fun searching icon_sad.gif
Alternatively, run a completely new wire from the LKL (likely referring to a specific component or connection point) to the LiMa connector (likely referring to the alternator), and be sure to disconnect the old wire between the two new connection points! This should also solve the problem.
Translated on 07-07-2026, 5:24.
Karma: +1098 / -0   Thank you, like it!
Post22-09-2014, 7:45    Subject: Charging control is acting up Quote
I also wanted to suggest that idea. I wouldn't bother debugging that.
If it happens to be of interest, you can always measure the transition resistance to ground.
Translated on 07-07-2026, 5:25.
DieselBär30x
Avatar-DieselBär30x
Post22-09-2014, 9:55    Subject: Re: Charging control is acting strangely Quote
Hello everyone!
ulf wrote:
... then no electricity should flow through the indicator when the alternator is connected. ...
+ with the engine/alternator running icon_exclaim.gif
Otherwise, electricity MUST flow through the display - regardless of the BNStG regulations or the regulator. icon_wink.gif
Regarding a cable defect, I would definitely take the time to precisely determine the cause (abrasion/cable break), because if it's the case, a wire rarely breaks on its own icon_confused.gif.
Translated on 07-07-2026, 5:26.
Post22-09-2014, 10:16    Subject: Re: Charging control is acting strangely Quote
DieselBär30x wrote:
Hello everyone!
Oh, darn, I meant disconnected alternator (as I also mentioned).
Translated on 07-07-2026, 5:28.
Post23-09-2014, 22:38    Subject: Charging control is acting up Quote
Hello!
Thank you for the answers.
I haven't had much time lately.
"But I checked the wiring harness."
It's still in there, neat and tidy, just like the first day.
Nothing was assembled, modified, repaired, or altered.
Therefore, I'm going to take the path of least resistance, which is the one that requires the least amount of work, and I'm going to start by assuming that the wiring harness is okay.
Everything else seems to be working fine.
Autoservice wrote:
The flickering without the limiter might also be related to the open DF line. When connecting B+, the display should turn off...
"That statement is amazing."
because that's really the case.
With the open DF cable, the charging indicator glows faintly.
If I apply 12V board voltage to a small test lamp, it is completely off. icon_eek.gif icon_eek.gif icon_eek.gif
Is there an explanation for that?
It seems like I'll probably have to install a new regulator soon.
Translated on 07-07-2026, 5:30.
Post24-09-2014, 1:28    Subject: Charging control is acting up Quote
Is there an explanation for this?
There's almost an explanation for everything. I'm roughly estimating it through induction.
Translated on 07-07-2026, 5:31.
Post24-09-2014, 6:54    Subject: Charging control is acting up Quote
Or rather, capacitive coupling?
Post24-09-2014, 8:12    Subject: Charging control is acting up Quote
I'm sticking with leakage current, because induction and capacitive coupling are high-frequency phenomena that I wouldn't expect to find in such an old vehicle's electrical system.
A leakage current path to ground that causes the glow plug to glow may be "saturated" to such an extent via a test lamp at the DF (distribution box) that the remaining current flowing through the glow plug is no longer sufficient to cause it to glow.
For me, this is a more straightforward explanation than induction or capacitive coupling.
@ Steffen:
Okay, here's the translation:
"If possible, please expand on the LKL, including a possible example." Parallel resistance.
Then measure the resistance of the DF wire (disconnected on the LiMa side) to ground -> it should show an infinite resistance.
Translated on 07-07-2026, 5:32.
Post30-09-2014, 19:56    Subject: Charging control is acting up Quote
Hello!
Today, I installed a new regulator.
That's it.
Everything is working normally again.
Hoping that this will remain the case in the future.
Thank you for your support!
Translated on 07-07-2026, 5:34.
Post30-09-2014, 20:02    Subject: Charging control is acting up Quote
No new posts Doku Golf 1J, Air conditioning compressor making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starter Motor Noise: VW Golf 4 & Similar Troubleshooting & Guides
No new posts Doku Caddy 9K bis 04/96, Trommelbremse macht Geräusche Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car Electrical Help: Get Tutoring Now! Transmission, Chassis, Body & Interior
No new posts Funny starting problems Diesel Engine Technology
No new posts Passat 97 komische Werte MWB 1/2 und MWB 8 On-Board Diagnostics (OBD)
No new posts Turbocharger Leak: Funny Discovery! Diesel Engine Technology
