A4 B6 1.8T BFB Fuel Pump
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post23-05-2015, 22:18    Subject: A4 B6 1.8T BFB Fuel Pump Quote
Evening.
I removed and disassembled the pump inside the tank, as mentioned in the A4 document.
The pump itself is from VDO, but unfortunately, I can't find it individually on the open market.
8E0919051L is the part number for the entire unit.
"Does anyone know where I can find VDO parts, or can someone tell me which pumps from other manufacturers (like Pierburg, etc.) I can use as a replacement?"
Boost pressure: 4 bar, 12V.
Translated on 09-07-2026, 16:21.
Post24-05-2015, 9:16    Subject: Re: A4 B6 1.8T BFB fuel pump Quote
http://www.conti-online.com/www/automotive_de_de/themes/passenger_cars/replac_parts/fuel_systems/
VDO wurde in 1991 an Mannesmann verkauft. Mannesmann wurde in 2001 bekanntlich an Vodafone "verkauft". Da Vodafone vom Mannesmann Konzern nur den Mobilfunk haben wollte, wurde der Konzern zerlegt. Die VDO ging über den Umweg ATECS an Siemens und später an Continental, welche dann auch noch von der Schäffler Gruppe per Aktienmehrheit aufgekauft wurde ..... icon_rolleyes.gif
Since 2008/2009, the brand name VDO has been gradually disappearing.
http://de.wikipedia.org/wiki/VDO_Automotive
Translated on 09-07-2026, 16:22.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post24-05-2015, 12:48    Subject: A4 B6 1.8T BFB Fuel Pump Quote
Siemens-VDO A2C53171435Z. We might have this in stock. It's the complete pre-lift pump, including the fuel level sender. If you're interested, we can chat via private message. I can give you prices when I'm back at work.
Passat Variant BGW 2005
Translated on 09-07-2026, 16:23.
klahaui
Avatar-klahaui
Post24-05-2015, 23:20    Subject: A4 B6 1.8T BFB Fuel Pump Quote
Evening.
da werd ich wohl auch keinen Erfolg haben die VDO Nummer umzuschlüsseln. icon_confused.gif
The Pierburg 7.02550.63 might fit, and it would cost me 75€. I might try that.
You can't open the new unit to see what's installed, Steffen? icon_twisted.gif
Translated on 09-07-2026, 16:24.
klahaui
Avatar-klahaui
Post26-05-2015, 19:24    Subject: A4 B6 1.8T BFB Fuel Pump Quote
I received the Pierburg part today and it fits perfectly. The vehicle is running normally again!
Thank you, Steffen, for your help; the price is excellent for the unit.
No new posts TDI Fuel Pump Priming: How to Bleed It Troubleshooting & Guides
No new posts Audi A3 accidentally filled with E10 fuel, fuel pump failure Gasoline Engine Technology
