Passat B7 TDI: VCDS Diagnostics, No Data Blocks
hharry
Karma: +2 / -1   Thank you, like it!
Post13-10-2014, 21:22    Subject: Passat B7 TDI: VCDS Diagnostics, No Data Blocks Quote
Hello everyone,
I bought a Passat Estate (station wagon) from the 2013 model year two weeks ago.
Now, the measurement blocks of the engine electronics cannot be read using VCDS version 12.12.3, as shown in the Screenshot.
Maybe I'm making a very simple mistake.
Can someone help me?
Harald.
 File size:  138.85 KB
 Viewed:  4012 times
Translated on 25-09-2026, 5:49.
Post13-10-2014, 21:37    Subject: Passat B7 TDI: VCDS Diagnostics, No Data Blocks Quote
Translated on 25-09-2026, 5:50.
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts Subaru Diagnostics: Using VCDS Hardware Troubleshooting & Guides
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts VCDS Mobile: Incorrect Data Display? Fix Now! On-Board Diagnostics (OBD)
No new posts A6 4A: No Diagnosis Possible On-Board Diagnostics (OBD)
No new posts Fabia: No diagnosis possible when factory radio is connec... On-Board Diagnostics (OBD)
No new posts Problems, no diagnosis with a Lupo 1.7 SDI AKU, built in ... On-Board Diagnostics (OBD)
