MisterD
Joined: 07/19/2014 Posts: 21 Karma: +2 / -0 Location: Stuttgart
19-07-2014, 18:55 Subject: P0299 Error: Low Turbocharger Boost Pressure |
Hello community,
I'm new here and signed up because of the problem described in the title.
I drive a Seat Leon 1.8 TSI (model year 2010) with approximately 95,000 km total mileage, of which 10,000 km were driven with a software optimization. Today, I accidentally discovered the error code "P0299" in the engine control unit's error memory.
"During the drive, I didn't notice anything unusual, so I assumed it was just an intermittent issue. The engine didn't go into limp mode, and the check engine light didn't come on in the instrument cluster."
Due to the chip tuning, I decided to log the boost pressure during a full-throttle acceleration. You can find the log file in the attachment.
Could the problem be a worn-out boost valve due to the increased boost pressure? I had previously felt a gradual loss of power at higher RPMs, but I thought it was due to temperature.
Dennis.
| Description: |
 Download |
| File name: |
LOG-01-115-003-006.CSV |
| File size: |
2.88 KB |
| Downloaded: |
1094 times |
Translated on 04-10-2026, 2:28.
mullemaus Guest
19-07-2014, 20:12 Subject: P0299 Error: Low Turbocharger Boost Pressure |
This is not uncommon. The load data  on these devices is often determined through the TV, not necessarily based on a target/actual map or comparison.
Translated on 04-10-2026, 2:29.
MisterD
20-07-2014, 11:47 Subject: P0299 Error: Low Turbocharger Boost Pressure |
Thanks in advance for your reply. I'm not an expert, and I suspect that your abbreviation "TV" refers to the duty cycle of the charge pressure control valve?
Unfortunately, today I was only able to check the valve control; a continuity test was not possible due to the lack of a lift platform. At least it did click  .
Ich hab auch nochmals eine Logfahrt gemacht, der Fehler trat nach LĂśschen nicht mehr auf, trotz allem kommt mir die Beschleunigung sehr wellig und unkonstant vor. Im Anhang noch der Auszug aus dem Fehlerspeicher und die neue Log-Datei (3. Gang).
Greetings.
Dennis.
| Description: |
 Download |
| File name: |
LOG-01-115-xxx-xxx.CSV |
| File size: |
3.25 KB |
| Downloaded: |
796 times |
| Description: |
 Download |
| File name: |
Log-Log.txt |
| File size: |
1.44 KB |
| Downloaded: |
819 times |
Translated on 04-10-2026, 2:30.
mullemaus Guest
20-07-2014, 12:16 Subject: P0299 Error: Low Turbocharger Boost Pressure |
The pressure appears to be consistently within the normal range and looks fine.
Check the rail pressure, as well as the low pressure at the fuel pump.
Translated on 04-10-2026, 2:31.
MisterD
20-07-2014, 14:05 Subject: P0299 Error: Low Turbocharger Boost Pressure |
Unfortunately, I couldn't find the fuel pump pressure reading. In which diagnostic trouble code (DTC) module is it usually displayed?
I was able to log the rail pressure, which seemed normal. Unfortunately, I forgot to record the RPM, but that's not a big deal.
In addition to the boost pressure, I also recorded the function of the N75 valve, which seems to be working as it should.
The error no longer appears... Maybe it was just a false alarm  .
| Description: |
 Download |
| File name: |
Ladedruck N75.CSV |
| File size: |
2.24 KB |
| Downloaded: |
821 times |
| Description: |
 Download |
| File name: |
Rail-Druck.CSV |
| File size: |
2.26 KB |
| Downloaded: |
767 times |
mullemaus Guest
20-07-2014, 14:18 Subject: P0299 Error: Low Turbocharger Boost Pressure |
I believe that low pressure is also used in the 103...106 and 140 series of Mercedes-Benz vehicles.
Translated on 04-10-2026, 2:32.
MisterD
23-07-2014, 12:09 Subject: P0299 Error: Low Turbocharger Boost Pressure |
I have now decided not to use a low-pressure system log, as the error has not occurred again.
Nevertheless, I proactively exchanged the SUV. I decided on the GFB DV+. For those who are interested:
Installing the K03 turbocharger without a lift is quite manageable if you remove the right front wheel and the wheel well. This gives you a clear view directly onto the SUV.
The result after removing the original part was that it was already partially porous, but without any obvious cracks. Nevertheless, the new part had a significant effect: the whistling sound from my turbocharger completely disappeared under full load. Therefore, I suspect that the membrane was indeed slightly leaky.
Best regards and thank you for the help  .
Translated on 04-10-2026, 2:33.
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Dßsseldorf
23-07-2014, 12:46 Subject: P0299 Error: Low Turbocharger Boost Pressure |
Thank you for the feedback  .
It would be great if you could let us know later whether the wastegate was actually the cause. We'll keep the thread open in the meantime. Thanks.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 04-10-2026, 2:34.
MisterD
27-07-2014, 13:33 Subject: P0299 Error: Low Turbocharger Boost Pressure |
The SUV was the problem. Yesterday, I drove a longer distance, including a section on the highway, and the car drives smoothly again.
There are no more errors in the memory.
Greetings.
Translated on 04-10-2026, 2:35.
27-07-2014, 13:58 Subject: P0299 Error: Low Turbocharger Boost Pressure |
Ok... Thank you  .
Edit: Moved back here for editing upon request
Translated on 04-10-2026, 2:36.
MisterD
Erbse78 likes this. |
30-08-2014, 15:04 Subject: P0299 Error: Low Turbocharger Boost Pressure |
Thank you very much!
I initially thought the problem had been fixed. However, the error reappeared after several more trips. I deleted the data again and tried to reproduce the issue.
Full throttle from the lowest RPM to the rev limiter in 2nd gear --> no issues.
Full throttle from the lowest RPM to the rev limiter in 3rd gear --> no issues.
Full throttle from the lowest RPM to the rev limiter in 4th gear --> no issues.
I was able to reproduce it by flooring the accelerator and shifting from 2nd gear directly to 4th gear.
Attached you will find both the log file, which was active when the error occurred, and the error memory entry.
I've already replaced the N75 sensor, so it shouldn't be the problem. The hose to the intercooler seemed to be in good condition.
Are there any other possible solutions, or do you think the problem lies with the software, even though it has been working flawlessly for over 10,000 kilometers?
Greetings.
| Description: |
 Download |
| File name: |
Durchzug 2-4 mit Fehlercode.CSV |
| File size: |
4.69 KB |
| Downloaded: |
524 times |
| Description: |
 Download |
| File name: |
Log 2.txt |
| File size: |
1.43 KB |
| Downloaded: |
645 times |
Translated on 04-10-2026, 2:37.
01-09-2014, 14:01 Subject: P0299 Error: Low Turbocharger Boost Pressure |
He never reaches the target boost pressure.
Is the wastegate stuck?
Translated on 04-10-2026, 2:38.
Profile PM Garage |
MisterD
06-09-2014, 8:11 Subject: P0299 Error: Low Turbocharger Boost Pressure |
Thank you for the response. How can I check this while it's installed, and are there any reference values that a non-expert like me can use to assess it?
Greetings.
Translated on 04-10-2026, 2:39.
06-09-2014, 8:36 Subject: P0299 Error: Low Turbocharger Boost Pressure |
MisterD wrote: | Hi,
Greetings |
Set Point: Boost Pressure - (specified)
Set Point: Boost Pressure - (target)
Profile PM WWW Garage |
MisterD
06-09-2014, 12:12 Subject: P0299 Error: Low Turbocharger Boost Pressure |
Okay, I'll log that and upload it here when I have the chance.
Greetings.
Translated on 04-10-2026, 2:40.
MisterD
07-10-2014, 12:46 Subject: P0299 Error: Low Turbocharger Boost Pressure |
Hello community,
Unfortunately, it's taken some time due to shift work and vacations, but today I finally got a chance to work on the car again using my laptop.
During the first scan, I noticed that the error in the engine control unit was no longer present. Over the past few weeks, I have driven over 4000 km, which was probably enough to reset the error counter  .
I still created a log of the boost pressure, and I can't find anything unusual there either. I'm starting to suspect that the problem might be in the software. What do you think? (Please ignore the last part, I accidentally recorded it again while decelerating.)
Greetings.
| Description: |
 Download |
| File name: |
| File size: |
4.81 KB |
| Downloaded: |
544 times |
Translated on 04-10-2026, 2:41.
