Fine-tuning electrical devices. Sunroof in the A3
donalexo
Post24-04-2003, 22:56    Subject: Fine-tuning electrical devices. Sunroof in the A3 Quote
Hello professionals!
"Does anyone know how to adjust the zero point of the electric sunroof on an Audi A3? At higher outside temperatures, my sunroof doesn't close completely. There's no leak causing water ingress or anything like that, but it doesn't close tightly enough that the seal doesn't have enough tension." This results in increased wind noise at higher driving speeds, and sometimes a slight pulling sensation can be felt.
The sunroof is operated via a rotary switch located on the headliner, which allows the user to select the desired position.
I suspect that there has been a slight zero-point drift in the position control system over the years, which would need to be corrected. That's my assumption. Now it's time for the professionals, those who have practical experience.
How can the default position (i.e., sunroof closed) be recalibrated?
Thank you very much.
Alex.
Touran 1.9 TDI, EZ 09/2004
donalexo
Post04-05-2003, 21:39    Subject: Fine-tuning electrical devices. Sunroof in the A3 Quote
Does anyone have a solution or approach for calibrating the electrical system? Sunroof? icon_sad.gif icon_sad.gif icon_sad.gif
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentation up to 05/99, sunroof stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Sunroof Rattle Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electronic Differential Lock Diesel Engine Technology
No new posts Electric Heater Not Working? Troubleshooting Tips Diesel Engine Technology
This topic is locked, you cannot edit or reply. Electric Window Regulator for Polo 6N2 (Solved) Transmission, Chassis, Body & Interior
No new posts A8 4E: Coding Electric Folding Mirrors On-Board Diagnostics (OBD)
