Turbocharger Replacement: How to Replace It
blackblizzard
Post01-12-2014, 14:59    Subject: Turbocharger Replacement: How to Replace It Quote
I want to replace the turbocharger on a 1.5L dCi (Renault) engine. (The shaft has some play, it's producing white/blue smoke, and there are grinding noises from 2300 RPM.)
The cause, in my opinion, is a lack of maintenance (e.g., the air filter and very old oil).
What else should I replace? I'll take a look at the oil lines and try to clean them.
Replace charge air hoses/coolers when replacing wood chips?
Should I perform an oil flush using cheap oil?
Translated on 01-08-2026, 16:26.
Post01-12-2014, 15:27    Subject: Turbocharger Replacement: How to Replace It Quote
You should definitely replace the oil line if there's even the slightest doubt that all dirt particles have been removed. If it's a hose, it should generally be replaced.
Because intercoolers should also be checked for debris if there's a possibility of shavings being present.
Translated on 01-08-2026, 16:27.
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Doku Sharan, Pfeifgeräusche vom Turbolader Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Transporter 7D, MKB ACV, Turbolader-Pfeifen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Upgrade Turbo: Wastegate to VTG Turbocharger Diesel Engine Technology
No new posts Replace V6 Injectors: Guide & Parts Diesel Engine Technology
No new posts Replace T4 Dual Mass Flywheel Diesel Engine Technology
No new posts Replace battery? Electrical Systems, Vehicle Electronics, Multimedia
