Engine failure, cause? Audi 3.0TDI Engine: ASB
schlauchdruide
Post13-11-2014, 11:49    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
as shown in the image, the pistons of cylinders 4-6
I have suffered greatly, and I can see the melting through the {WINDOW/GLASS}.
Fuel injectors, as well as almost all exhaust valves, are burned.
Cylinders 1-3 are not affected.
What could be the cause that only this cylinder bank is affected? All injectors are original and from the first series. (AB)
Is it possible to upload a picture from a smartphone?
If not, I will download them later, if necessary.
Post13-11-2014, 12:01    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
vwSchrauber
Karma: +42 / -0   Thank you, like it!
Post13-11-2014, 13:39    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Translating...
[Translating...]
schlauchdruide
Post13-11-2014, 13:53    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
Please explain the function of the {VALVE} in more detail.
Post13-11-2014, 14:02    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
Perhaps one of the cylinder heads didn't get enough combustion air, and is therefore overheating...
vwSchrauber
Post13-11-2014, 14:03    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
For each cylinder bank, there is a camshaft unit. In the servo motors, plastic gears are used, which will eventually experience tooth wear.
If the servo motor's position monitoring doesn't work, then the control valves remain closed even under high load, and the affected cylinders don't get enough air (because the filling channel is not open).
Due to the lack of air, the combustion process gets closer to the piston material, and the exhaust gas temperature also increases significantly. Since the other cylinder bank produces "healthy" exhaust gases and the earlier EU4 engines were not monitored as strictly, an error is usually not displayed until the engine is essentially dead.
EDIT: There is a characteristic parameter for the position of the control valves. Anyone who wants to eliminate the problem from the outset can have a competent chiptuner "adjust" the KF, which reduces the adjustment frequency and, consequently, the risk of failure.
schlauchdruide
Post13-11-2014, 14:16    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
That must be the exact cause, because the exhaust temperatures were so high that the cables in the area around the pre-catalyst melted, including the OT (Oxygen Sensor) connection, leaving only a lump.
Thank you very much!
Now I can finally sleep again.
vwSchrauber
Post13-11-2014, 15:56    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
Of course, this also means that the DPF probably needed to be regenerated more often, because somewhere the soot generated due to the lack of air has to go... and this also promotes high exhaust temperatures.
The 2.7/3.0 TDI engines already have air-gap-isolated (double-walled) manifolds. There shouldn't get *that* hot.... or does the melted connector sit at the back where the (intact) exhaust pipes lead to the turbocharger?
schlauchdruide
Post13-11-2014, 16:38    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
Exactly. The connector is attached to the gearbox bell housing. The throttle and exhaust pipe are located in this area. Even the Vorkat has strong initial colors.
Thank you again.
chli1976
Karma: +185 / -0   Thank you, like it!
Post21-11-2014, 7:27    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
Can you upload the images, please?
VCDS
schlauchdruide
Tagessuppe and chli1976 likes this.
Post21-11-2014, 9:16    Subject: Images Quote
Here are a few pictures.
 Zylinderkopf ASB Motor
 File size:  310.35 KB
 Viewed:  5498 times
 Angeschmolzener Kolben, ASB Motor
 File size:  254.01 KB
 Viewed:  5664 times
 File size:  300.5 KB
 Viewed:  11144 times
vwSchrauber
Post27-11-2014, 17:54    Subject: Engine failure, cause? Audi 3.0TDI Engine: ASB Quote
It seems like you were lucky and the cylinder walls didn't get damaged.
No new posts Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum sy... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Bubbles: Find the Root Cause & Fix It! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touareg 3,0TDI MKB:BKS - Motorschaden Ursache? Diesel Engine Technology
No new posts Engine Failure Causes: What You Need to Know Diesel Engine Technology
No new posts Timing belt, Audi A3 8V1 2.0TDI CRBC and Golf 7 2.0TDI CRLB Diesel Engine Technology
No new posts Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp e... Diesel Engine Technology
