Mc_Givertechnik Schrauber
Joined: 02/27/2003 Posts: 390 Karma: +3 / -0 Location: Graz Österreich 2010 Volkswagen T5 Premium Support
31-05-2013, 21:21 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Hello!
I retrofitted the tire pressure monitoring system (TPMS) to my T5GP. Since it only involves connecting a wire to the ABS control unit on the hydraulic block, it's actually a fairly simple task.
The original button was connected according to the wiring diagram. During testing, a positive signal is also present at the connector of the ABS control unit when the SET button is pressed, indicating that the switch is functioning correctly.
Unfortunately, I'm having a lot of trouble with the coding process. While the tire pressure monitoring system (TPMS) can be modified through long coding in the KI (instrument cluster), the change is confirmed with "OK" and "Coding accepted" when saving. However, when disconnecting and reconnecting to the control unit, the new coding is lost. It's as if I haven't done anything at all. I've tried multiple times, with the ignition off and on, and on different days, using both the current DE version and the current BETA version of VCDS, but it simply doesn't work.
The ABS coding was done by...
alt: 108724AD09A7089924A6907A 6A 6410 on
"new: 108724AD09A7089924A6907A 6B 6410 modified. Sebastian was very helpful with this, and I'd like to thank him."
Maybe someone can give me a tip, thank you.
Greetings,
Peter.
| Description: |
 Download |
| File name: |
RPK LOG.txt |
| File size: |
9.64 KB |
| Downloaded: |
1564 times |
VW T5 GP Multivan Startline CAAC 2,0 CRD 103 KW, Audi A2 1,4 16V AUA 2001, Audi A2 1,4 16V AUA 2003;Renault Zoe PHII 135 2020;
Translated on 07-10-2026, 0:27.
Profile PM Email Garage |
31-05-2013, 22:03 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
The software being used is not a version that we support. Customer support without a ticket is generally only available for VCDS-Plus.
How did you terminate the connection to the control units after the reprogramming?
Sequence of clicks, including the timing?
Translated on 07-10-2026, 0:29.
Profile PM WWW Garage |
01-06-2013, 7:31 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Hello Rainer!
Sorry, I grabbed the wrong log file. The correct one is attached.
To program. Established a connection to the ECU (Engine Control Unit), selected the "long coding" option, checked the box for "tire pressure monitoring," and clicked "apply" or "save." (The exact wording is not precisely recalled.) The new coding was accepted and confirmed with "OK." The connection to the ECU was terminated by returning to the main menu.
Peter.
| Description: |
 Download |
| File name: |
RPK LOG.txt |
| File size: |
9.79 KB |
| Downloaded: |
875 times |
Translated on 07-10-2026, 0:30.
01-06-2013, 11:24 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Please address the points I have raised.
Translated on 07-10-2026, 0:31.
01-06-2013, 20:51 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Hello Rainer!
Here are all the steps of the encoding process.
Turn on the vehicle ignition => Open VCDS => Control modules => 17 Instrument cluster => 07 Coding => Long coding assistant => Byte2 Bit0 Tire pressure monitoring system (TPMS) active/installed => Check the box => Close => New coding 160F01 => Code => Wait approximately 3 seconds => Coding accepted - OK => Click OK => Connection terminated, return to 06 => Back (main menu) => Exit => Turn off the ignition => Remove the key => Wait 20 seconds => Turn on the ignition again => Open VCDS => Control module => 17 Instrument cluster => 07 Coding => Restore the previous coding 169F00.
Everything runs smoothly in one go, without any pauses, except for the 3-second waiting time after the "encoding" process.
Here, the question arises whether the AI treats RDK and RPK the same way. Technically, these two things are fundamentally different. The idea that the AI still needs to be programmed in a certain way did not originate from me. I'm now clinging to any helpful suggestion I can find.
To be honest, I have no idea where any changes need to be made in the code for this particular issue.
Greetings, Peter.
P.S.: And here's a complete scan of the document, just taken.
| Description: |
 Download |
| File name: |
Log-G-96XXX-01062013-WV2ZZZ7HZBHXXXXXX-27808.txt |
| File size: |
9.83 KB |
| Downloaded: |
697 times |
Translated on 07-10-2026, 0:33.
01-06-2013, 21:57 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Quote: | | Serial number: 00000000000000 |
Why doesn't your instrument cluster have a serial number? Are these now again "knock-off" parts, like in one of the recent topics ("No Band-End Programming")?
Are there any useful default settings for WSC (Weißes Schwarzes Chaos) etc. in the VCDS program settings?
Translated on 07-10-2026, 0:35.
02-06-2013, 7:21 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Hello Rainer!
I assume that VW itself doesn't install "knock-off parts," right?
It's the original speedometer, but I could ask the dealer if they replaced the instrument cluster; I certainly didn't.
And the fact that I was unknowingly sold "spare parts" is already unpleasant enough, and you really don't have to dwell on it  , but it seems like this will haunt me for a while.
The AI thing reminds me of something. Sometimes, the AI tends to produce unmotivated, acoustic signals. This is slowly raising the suspicion that the AI might be malfunctioning. On June 10th, the bus will be back at the service center, and I'll bring up the issue then.
Greetings,
Peter.
WSC is being reviewed.
Translated on 07-10-2026, 0:37.
02-06-2013, 13:39 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Quote: | | The thing about AI brings back memories. Sometimes, the AI tends to produce unmotivated, acoustic signals. |
So, either it's defective or someone tampered with the speedometer incorrectly.
On my vehicles, there's a serial number listed everywhere. Most of the cars in the forum also have one, but some of the problem cars don't. Perhaps this is a marker for "mileage tampering"?  It would certainly be interesting to see if a definitely newly purchased T5, without any mileage manipulation, has a serial number or not.
Background: The serial number is very likely stored in the EEPROM, along with the configuration data. If there's any corruption or inconsistency in the EEPROM, it can sometimes lead to problems when making configuration changes.
Edit: A Google search didn't yield any results for other models that included a serial number. I'm now starting to think that it might be normal for some models to have a serial number and others not.
What about WSC etc. in the program settings?
Translated on 07-10-2026, 0:39.
matthiasTDI96 Profi-Schrauber
02-06-2013, 16:39 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
I have a serial number in the T5. However, mine is not the older generation with the red and blue AI indicator.
Translated on 07-10-2026, 0:40.
02-06-2013, 19:53 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
MJ 2013 T5.2 (Edition 25) - Demo vehicle from a local dealer:
Code: | Adresse 17: Kombiinstrument (J285) Labeldatei: RKS\5K0-920-xxx-17.clb
Teilenummer SW: 7E0 920 870 E HW: 7E0 920 870 E
Bauteil: KOMBI H04 0305
Seriennummer: 00000000000000
Codierung: 160F01
Betriebsnr.: WSC 02756 790 50316
ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_VN75.rod |
"Another T5.2 MJ from 2012, as posted in a forum:"
Code: | Adresse 17: Schalttafeleinsatz (J285) Labeldatei: DRV\5K0-920-xxx-17.clb
Teilenummer SW: 7E0 920 880 C HW: 7E0 920 880 C
Bauteil: KOMBI H04 0206
Codierung: 160F00
Betriebsnr.: WSC 00000 790 50316
ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04089
Translated on 07-10-2026, 0:41.
Profile PM Garage |
02-06-2013, 21:30 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Thank you, Martin!
I was also planning to put something together.
And by the way:
I bought my T5.2 from a VW dealer in November 2010, and it had 12 kilometers on the odometer.
So far, only one dealer has performed maintenance on this vehicle, and very often repairs. The list of defects for this vehicle is extremely long and wouldn't be appropriate to include here.
Since then, I've successfully upgraded various components without any coding issues: MFL, MMI, AHK (trailer hitch), RNS510 (yes, with invoice and warranty), FSE-Premium, Rear-Assist, SWR (steering wheel controls), original Bi-Xenon headlights, and tailgate unlocking. However, I encountered problems with the ALWR (automatic tailgate closing) system because I was apparently sold illegal goods. Although it came with an invoice from a still-active company and all the usual warranties, the control unit was not legally distributed and was not fully programmed. A control unit from a VW dealer resolved the issue.
So far, the electrical work on the T5.2 has only included updating the Body Control Module (BCM) and the engine control unit, replacing both keys, and replacing the left door lock. Yes, I think that covers everything.
WSC: There is NO WSC configured in the settings, only zeros.
I've read before that this can lead to problems, but unfortunately, I didn't think of that in this context.
Question: Can I use any code there, or are there specific guidelines that the WSC must meet?
Greetings,
Peter.
Translated on 07-10-2026, 0:43.
02-06-2013, 21:57 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Mc_Givertechnik wrote: | | Question: Can I use any code there, or what guidelines must the WSC meet? |
Well, one might get the idea to simply put something together from the auto-scan...
Translated on 07-10-2026, 0:45.
02-06-2013, 22:05 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Hello Rainer!
The idea was already there. For example, I entered 02756 790 50316, saved it, and then I got the message that the change would only take effect after saving and restarting VCDS. I did that, and... it showed all zeros again. Okay, let's try again... I opened VCDS, went to settings, entered the WSC, saved it, closed the program, and then I searched the internet for a while. Now, just now, after receiving your message, I opened VCDS again, and lo and behold, it's working.
Question: I am using Windows 8 64-bit. Could there be a connection between this and the problems I'm experiencing? I mean the need to repeat certain operations multiple times until they finally work?
Greetings,
Peter.
P.S.: Tomorrow, I will try the coding process again, now that I have the workshop code, and I will report back on the results.
Translated on 07-10-2026, 0:46.
03-06-2013, 9:39 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Quote: | | I am using Windows 8 64-bit. Could there be a connection between this and the problems you are experiencing? I mean, is it related to the need to repeat some operations multiple times until they work? |
No. With a bit of bad luck, it might be VAG's intention that users have to pay at the counter and with a cable, because the instrument cluster software is designed accordingly.
Do you have a T5 model that's as similar as possible to this one, and that already has this feature implemented, so I can compare?
Translated on 07-10-2026, 0:48.
03-06-2013, 21:30 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Quote: |
Do you have a T5 that is as similar as possible, and already has that feature, for comparison? |
Unfortunately, no.
Greetings,
Peter.
Translated on 07-10-2026, 0:49.
04-06-2013, 14:00 Subject: T5 GP RPK Upgrade: Solved Coding Issues |
Hello!
Okay, I'm back on the bus again and I've tried it again. This time, I used a pre-programmed workshop code. Everything behaves the same way; the initially accepted coding is gone again after reconnecting to the control unit.
I also tried to reverse the coding in the ABS control unit, which worked smoothly. Afterwards, I tried to code the instrument cluster, but the process is the same, and the coding isn't saved permanently.
It doesn't matter if you turn off the ignition after coding, wait a bit, and then turn it back on; the coding won't stick.
Peter.
Translated on 07-10-2026, 0:50.
