ECU differences: EDC15 vs. EDC15+
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post07-12-2014, 11:17    Subject: ECU differences: EDC15 vs. EDC15+ Quote
Hello everyone.
The engine control unit (ECU) in my Lupo 1.4 TDI has failed.
No more starts are possible, and it can no longer be accessed with VCDS.
Power supply is okay, but it also depends on the device.
Now, I would install a used replacement part. What should I pay attention to when purchasing the right control unit?
I have received several offers where the part number from VW is 045 906 019 S and the part number from Bosch is 0 281 010 529, and they match.
My control unit is from April 27, 2000, and the replacement would be from February 10, 2002.
"On my old one, it just says 'Diesel', but on some others, it says 'Diesel EDC15+'."
Is there a difference?
What exactly should I pay attention to in order to buy the right replacement part?
Perhaps the software version is different; how can I determine that?
Regards, Mpire.
Here's another older car scan from MSTG.
Vehicle type: 6X - VW Lupo
Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
Vehicle Identification Number: WVWZZZ6XZ1Wxxxxxx Mileage: 103,330 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Label file: RKS\045-906-019-AMF.lbl
Part number: 045 906 019 S.
Component: 1.4L R3 EDC G040SG 1208
Encoding: 00005
Operating number: WSC 01236
VCID: 25459E879571
WVWZZZ6XZ1Wxxxxxxx
No errors found.
Readiness: 0 0 X X X
Post07-12-2014, 11:46    Subject: ECU differences: EDC15 vs. EDC15+ Quote
You need: 045 906 019 S.
What else is written there is mostly unimportant.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post07-12-2014, 15:09    Subject: ECU differences: EDC15 vs. EDC15+ Quote
Okay. Thank you.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post11-12-2014, 9:05    Subject: Hello everyone Quote
Unfortunately, we can't get the Lupo to start.
The "new" control unit with the same number has been installed, and the engine at least starts briefly, but then the immobilizer shuts it off. I didn't receive a code tag from the original owner.
He's been at VW since yesterday, but they're having trouble with the configuration process because the system in Wolfsburg is interrupting the new coding process. The VW dealer wants to replace the engine control unit (ECU), window regulator, and reading coil.
What options do I have now? I'm really at a loss, as we urgently need the vehicle.
Regards, Mpire.
chli1976
Karma: +185 / -0   Thank you, like it!
Post11-12-2014, 10:07    Subject: ECU differences: EDC15 vs. EDC15+ Quote
What generation of immobilizer system does it have, generation 1 or 2?
Vehicles manufactured in 1998 should still be of the first generation. Then you need a login.
A complete car scan would also be beneficial.
Either find someone who can read the login data from the Steuergerät (control unit) with ID 25, or disable the immobilizer (Immo).
VCDS
Post11-12-2014, 10:36    Subject: ECU differences: EDC15 vs. EDC15+ Quote
Determine the WFS generation.
For WFS2, which is within the realm of possibility, only the adaptation channel 0 needs to be reset in the combination instrument (address 17) by writing a value of 0.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post11-12-2014, 13:18    Subject: ECU differences: EDC15 vs. EDC15+ Quote
Lupo is running again.
Up to production date 06/2000, the Lupo WFS1 was equipped with an external WFS control unit. The "new" control unit is from 2/2002 and, despite having the same part number WFS2, which is then integrated into the instrument cluster.
That's what the repair company said. VW couldn't tell me anything about it icon_eek.gif.
The "old" defective device was opened to inspect it. The chip was re-soldered because there was suspicion of a faulty solder joint. The data was re-flashed. Nothing more needed to be programmed; the vehicle is running perfectly again, and the error memory is clear.
Thank you for your quick help; that was a good tip about WFS generation.
Regards, Mpire.
Post11-12-2014, 14:58    Subject: ECU differences: EDC15 vs. EDC15+ Quote
Actually, nothing should have needed to be soldered onto the control unit in the first place, as it has been readable and writable via OBD since time immemorial. Consequently, the cause of the error would also have been eliminated. icon_wink.gif
If you had mentioned it from the beginning, I would have also suggested checking it out.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post11-12-2014, 19:23    Subject: ECU differences: EDC15 vs. EDC15+ Quote
Nothing had ever been soldered to the control unit before. It had never been removed. However, it was hanging loosely because one of the plastic holders was broken. It was opened based on suspicion alone.
Gruss Mpire.
Post11-12-2014, 19:26    Subject: ECU differences: EDC15 vs. EDC15+ Quote
Okay, thank you for the feedback!
No new posts EDC15 Steuergeräte, Software updatefähig Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU Remapping: Unlock EDC15 Potential On-Board Diagnostics (OBD)
No new posts Bosch EDC15 Wiring Diagram Needed On-Board Diagnostics (OBD)
No new posts AEL/ACV/AJT-Motor, EDC15 öffnet ELAB nicht Diesel Engine Technology
No new posts AGR valve not being activated, Audi A2 1.2 TDI EDC15 Diesel Engine Technology
