Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum system (Solution)
Karma: +807 / -0   Thank you, like it!
Post16-03-2015, 12:35    Subject: Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum system Quote
In certain vehicles with 3.0 TDI engines from the 2012 to 2013 model years, oil may enter the vacuum system, which can, in the medium term, damage the membranes in the brake booster (Caution: in the event of a fault, this may result in reduced braking performance).
Troubleshooting: Installing a vacuum line with a check valve.
The brake booster should be checked for oil leaks.
Service campaign with recall.
Ratings - Audi A4, A5, A6, A7, Q5, Q7 3.0 TDI, Oil in the vacuum system
No new posts Vacuum system and control pneumatics in the TDI Technical Articles
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Audi A3 8V1 & Golf 7 2.0 TDI Diesel Engine Technology
No new posts Differences between the 2.0 TDI 120hp and 2.0 TDI 143hp e... Diesel Engine Technology
No new posts Vacuum Leak: How to Find and Fix It Diesel Engine Technology
No new posts 2.0 TDI PD Injectors: VW Audi Performance Diesel Engine Technology
