Jan03 Blaumann
Joined: 08/24/2003 Posts: 142 Karma: +6 / -0 Location: Dänemark 2010 Volkswagen Polo Free account, no CAN development support
05-02-2015, 13:24 Subject: Nockewellen-Probleme: Fotos und Lösungen |
Hi.
Since it's always nice to look at some pictures, I wanted to share a few photos of a 1.9PD engine that has unfortunately experienced the well-known camshaft wear issue.
Car: Touran, 2006, 1.9 TDI 90 hp without DPF (engine code: BXF), 180,000 km. Has been chipped for approximately 20,000 km (now ~130 hp).
Driving profile: Primarily short distances, but in the summer, longer distances are covered with a caravan. To the best of my knowledge, the owner is careful and avoids stressing the engine when it's cold, especially considering the performance optimization.
Symptoms: Sudden, speed-dependent pumping or hissing noise (similar to a steam locomotive) coming from one cylinder. This is also noticeable in the intake hose. No error codes in the engine control unit (ECU), and no noticeable loss of power.
Repairs: New camshaft, new hydraulic lifters, new timing belt, etc.
Only the first camshaft lobe was worn, as can be seen in the photo. The others still had their original coating. Also, only the first hydraulic lifter was damaged, while the rest showed only slight signs of wear, which I would consider normal after 180,000 km.
/Jan
| Description: |
| Sieben der acht Nocken sehen so aus. |
 Download |
| File name: |
DSCN7850.JPG |
| File size: |
2.99 MB |
| Downloaded: |
1218 times |
| Description: |
 Download |
| File name: |
DSCN7852.JPG |
| File size: |
2.9 MB |
| Downloaded: |
754 times |
| Description: |
 Download |
| File name: |
DSCN7849.JPG |
| File size: |
2.92 MB |
| Downloaded: |
730 times |
| Description: |
 Download |
| File name: |
DSCN7845.JPG |
| File size: |
3.01 MB |
| Downloaded: |
738 times |
Translated on 02-11-2026, 17:53.
Profile PM Garage |
DomBay
Joined: 01/03/2015 Posts: 15 Karma: +2 / -0 Location: Bayern
06-02-2015, 11:29 Subject: Nockewellen-Probleme: Fotos und Lösungen |
That's truly phenomenal!
Did you happen to follow my topic/thread?
/viewtopic.php?t=27882
Greetings.
Translated on 02-11-2026, 17:55.
Jan03 Blaumann
06-02-2015, 14:34 Subject: Nockewellen-Probleme: Fotos und Lösungen |
Yes, I saw your post, and that's why I thought it would be worth sharing this case here as well, since they seem quite similar.
And this problem, unfortunately, seems to be absolutely not an isolated case.
/Jan
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2406 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
07-02-2015, 17:52 Subject: Nockewellen-Probleme: Fotos und Lösungen |
Hi Jan,
Thank you for the pictures.
Do you have any indication of whether the correct type of oil was used?
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 02-11-2026, 17:56.
Profile PM Garage |
