P0299 Error: Low Turbocharger Boost Pressure
Go to page: 1, 2  Next
MisterD
Post19-07-2014, 18:55    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Hello community,
I'm new here and signed up because of the problem described in the title.
I drive a Seat Leon 1.8 TSI (model year 2010) with approximately 95,000 km total mileage, of which 10,000 km were driven with a software optimization. Today, I accidentally discovered the error code "P0299" in the engine control unit's error memory.
"During the drive, I didn't notice anything unusual, so I assumed it was just an intermittent issue. The engine didn't go into limp mode, and the check engine light didn't come on in the instrument cluster."
Due to the chip tuning, I decided to log the boost pressure during a full-throttle acceleration. You can find the log file in the attachment.
Could the problem be a worn-out boost valve due to the increased boost pressure? I had previously felt a gradual loss of power at higher RPMs, but I thought it was due to temperature.
Dennis.
LOG-01-115-003-006.CSV
 File name:  LOG-01-115-003-006.CSV
 File size:  2.88 KB
 Downloaded:  1095 times
Translated on 04-10-2026, 2:28.
mullemaus
Post19-07-2014, 20:12    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
This is not uncommon. The load data icon_wink.gif on these devices is often determined through the TV, not necessarily based on a target/actual map or comparison.
Translated on 04-10-2026, 2:29.
MisterD
Post20-07-2014, 11:47    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Thanks in advance for your reply. I'm not an expert, and I suspect that your abbreviation "TV" refers to the duty cycle of the charge pressure control valve?
Unfortunately, today I was only able to check the valve control; a continuity test was not possible due to the lack of a lift platform. At least it did click icon_smile.gif.
Ich hab auch nochmals eine Logfahrt gemacht, der Fehler trat nach LĂśschen nicht mehr auf, trotz allem kommt mir die Beschleunigung sehr wellig und unkonstant vor. Im Anhang noch der Auszug aus dem Fehlerspeicher und die neue Log-Datei (3. Gang).
Greetings.
Dennis.
LOG-01-115-xxx-xxx.CSV
 File name:  LOG-01-115-xxx-xxx.CSV
 File size:  3.25 KB
 Downloaded:  797 times
Log-Log.txt
 File name:  Log-Log.txt
 File size:  1.44 KB
 Downloaded:  820 times
Translated on 04-10-2026, 2:30.
mullemaus
Post20-07-2014, 12:16    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
The pressure appears to be consistently within the normal range and looks fine.
Check the rail pressure, as well as the low pressure at the fuel pump. icon_wink.gif
Translated on 04-10-2026, 2:31.
MisterD
Post20-07-2014, 14:05    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Unfortunately, I couldn't find the fuel pump pressure reading. In which diagnostic trouble code (DTC) module is it usually displayed?
I was able to log the rail pressure, which seemed normal. Unfortunately, I forgot to record the RPM, but that's not a big deal.
In addition to the boost pressure, I also recorded the function of the N75 valve, which seems to be working as it should.
The error no longer appears... Maybe it was just a false alarm icon_smile.gif.
Ladedruck N75.CSV
 File name:  Ladedruck N75.CSV
 File size:  2.24 KB
 Downloaded:  822 times
Rail-Druck.CSV
 File name:  Rail-Druck.CSV
 File size:  2.26 KB
 Downloaded:  768 times
mullemaus
Post20-07-2014, 14:18    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
I believe that low pressure is also used in the 103...106 and 140 series of Mercedes-Benz vehicles.
Translated on 04-10-2026, 2:32.
MisterD
Post23-07-2014, 12:09    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
I have now decided not to use a low-pressure system log, as the error has not occurred again.
Nevertheless, I proactively exchanged the SUV. I decided on the GFB DV+. For those who are interested:
Installing the K03 turbocharger without a lift is quite manageable if you remove the right front wheel and the wheel well. This gives you a clear view directly onto the SUV.
The result after removing the original part was that it was already partially porous, but without any obvious cracks. Nevertheless, the new part had a significant effect: the whistling sound from my turbocharger completely disappeared under full load. Therefore, I suspect that the membrane was indeed slightly leaky.
Best regards and thank you for the help icon_wink.gif.
Translated on 04-10-2026, 2:33.
Post23-07-2014, 12:46    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Thank you for the feedback icon_wink.gif.
It would be great if you could let us know later whether the wastegate was actually the cause. We'll keep the thread open in the meantime. Thanks.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 04-10-2026, 2:34.
MisterD
Post27-07-2014, 13:33    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
The SUV was the problem. Yesterday, I drove a longer distance, including a section on the highway, and the car drives smoothly again. icon_smile.gif
There are no more errors in the memory.
Greetings.
Translated on 04-10-2026, 2:35.
Post27-07-2014, 13:58    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Ok... Thank you icon_wink.gif.
Edit: Moved back here for editing upon request icon_wink.gif
Translated on 04-10-2026, 2:36.
MisterD
Erbse78 likes this.
Post30-08-2014, 15:04    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Thank you very much!
I initially thought the problem had been fixed. However, the error reappeared after several more trips. I deleted the data again and tried to reproduce the issue.
Full throttle from the lowest RPM to the rev limiter in 2nd gear --> no issues.
Full throttle from the lowest RPM to the rev limiter in 3rd gear --> no issues.
Full throttle from the lowest RPM to the rev limiter in 4th gear --> no issues.
I was able to reproduce it by flooring the accelerator and shifting from 2nd gear directly to 4th gear.
Attached you will find both the log file, which was active when the error occurred, and the error memory entry.
I've already replaced the N75 sensor, so it shouldn't be the problem. The hose to the intercooler seemed to be in good condition.
Are there any other possible solutions, or do you think the problem lies with the software, even though it has been working flawlessly for over 10,000 kilometers?
Greetings.
Durchzug 2-4 mit Fehlercode.CSV
 File name:  Durchzug 2-4 mit Fehlercode.CSV
 File size:  4.69 KB
 Downloaded:  525 times
Log 2.txt
 File name:  Log 2.txt
 File size:  1.43 KB
 Downloaded:  646 times
Translated on 04-10-2026, 2:37.
Post01-09-2014, 14:01    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
He never reaches the target boost pressure.
Is the wastegate stuck?
Translated on 04-10-2026, 2:38.
MisterD
Post06-09-2014, 8:11    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Thank you for the response. How can I check this while it's installed, and are there any reference values that a non-expert like me can use to assess it?
Greetings.
Translated on 04-10-2026, 2:39.
Post06-09-2014, 8:36    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Greetings
Set Point: Boost Pressure - (specified)
Set Point: Boost Pressure - (target)
MisterD
Post06-09-2014, 12:12    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Okay, I'll log that and upload it here when I have the chance.
Greetings.
Translated on 04-10-2026, 2:40.
MisterD
Post07-10-2014, 12:46    Subject: P0299 Error: Low Turbocharger Boost Pressure Quote
Hello community,
Unfortunately, it's taken some time due to shift work and vacations, but today I finally got a chance to work on the car again using my laptop.
During the first scan, I noticed that the error in the engine control unit was no longer present. Over the past few weeks, I have driven over 4000 km, which was probably enough to reset the error counter icon_smile.gif.
I still created a log of the boost pressure, and I can't find anything unusual there either. I'm starting to suspect that the problem might be in the software. What do you think? (Please ignore the last part, I accidentally recorded it again while decelerating.)
Greetings.
 File size:  4.81 KB
 Downloaded:  545 times
Translated on 04-10-2026, 2:41.
No new posts P0299 Error: Boost Control System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost pressure control exceeded 3.0 bar, P0299 code / rou... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost pressure control, regulation limit exceeded (low) Gasoline Engine Technology
No new posts P0299: Load Pressure Control - Control Limit Undershot Diesel Engine Technology
No new posts P0299: Limit exceeded, please comment on logs Diesel Engine Technology
This topic is locked, you cannot edit or reply. Boost Pressure Control: Limit Exceeded Diesel Engine Technology
