Throttle Body Motor: Circuit Fault (P2100) (Solution)
Post01-03-2015, 12:30    Subject: Throttle Body Motor: Circuit Fault (P2100) Quote
P2100 - Throttle control motor, circuit malfunction.
Possible symptoms:
- Power loss
Possible causes:
- Faulty wiring or connector (open circuit or short circuit).
- Throttle body module failure.
- Very rare: Engine control unit (ECU) failure.
Solutions:
- Check the wiring and connectors.
- Check the throttle control module (TCM).
- Replace the engine control unit (for testing purposes).
See also: https://community.dieselschrauber.org/en/viewtopic.php?t=26107
Translated on 07-09-2026, 4:10.
Ratings - Throttle Body Motor: Circuit Fault (P2100)
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P1118 - Oxygen Sensor Heater Circuit Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lambda sensor control (electrical) (Fault in the electric... On-Board Diagnostics (OBD)
No new posts PD Unit Power Issues: Troubleshooting Stuttering On-Board Diagnostics (OBD)
No new posts Glow Plug Circuit Fault: P0672 & P0673 Codes Diesel Engine Technology
No new posts WFS Errors: Troubleshooting and Solutions Diesel Engine Technology
