Audi A6, Error after trailer hitch retrofit
maendy
Post22-02-2015, 18:01    Subject: Audi A6, Error after trailer hitch retrofit Quote
I have retrofitted a used trailer hitch with a specific electrical kit.
The lighting for the trailer works, and I was also able to deactivate the parking sensors using VCDS. Unfortunately, the trailer module is not properly registered, and there are errors in the braking electronics...
can someone please help me icon_sad.gif icon_sad.gif best regards, Maendy
Saturday, February 21, 2015, 13:33:24:46857
VCDS -- Windows-based VAG/VAS Emulator
VCDS Version: RKS 14.10.1.2
Data Status: 20150213
Vehicle Identification Number: WAUZZZ4F47N065170 Vehicle Registration Plate: A6
Odometer: 240250km Repair order:
Vehicle Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 69 72 76 77
Vehicle Identification Number: WAUZZZ4F47N065170 Kilometerstand: 240250km
00-Yaw sensor -- Status: OK 0000
01-Engine Electronics -- Status: Error 0010
02-Transmission -- Status: OK. 0000
03-Brake Electronics -- Status: Error 0010
05-Access/Start Report -- Status: Error 0010
07-Part Number/Operating Unit -- Status: Error 0010
08-Climate/Heating System - Status: Error 0010
09-Main Electrical System -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel electronics -- Status: OK 0000
17-Switch Panel Insert -- Status: OK 0000
19-Diagnosis Interface -- Status: Error 0010
25-Way Ignition Switch -- Status: Error 0010
37-Navigation -- Status: Error 0010
42-door electric Driver -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK. 0000
4F-Central Electrical II -- Status: OK 0000
52-door electric Passenger. -- Status: OK. 0000
53-Parking Brake -- Status: OK 0000
55-Light fixture regulator -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Control -- Status: OK 0000
62-door electric, right-hand drive -- Status: OK 0000
69 supporters -- Status: not logged in 0001
72-door electric high roof -- Status: OK 0000
76-Parking Assist -- Status: OK 0000
77-Phone -- Status: OK 0000
Address 01: Engine Electronics Label file: DRV\059-907-401-ASB.clb
Part Number SW: 4F0 910 402 E HW: 4F0 907 401 C
Part Number: 3.0L V6TDI G000AG 0020
Revision: --H03--- Serial Number:
Encoding: 0011372
Operating Number: WSC 02334 785 00200
VCID: 1F498C13CE0AD5D977D-804A
3 error codes found:
005491 - Valve, left, for engine storage (N144)
P1573 - 001 - Interruption
Environmental Conditions:
Error Status: 01100001
Error Priority: 0
Frequency of Errors: 1
Lost Count: 255
Kilometerstand: 237212 km
Time: 0
Date: 2015.01.15
Time: 11:07:06
Speed: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Voltage: 11.86 V
Binary Value: 1
Binary Value: 1
Binary Value: 1
005660 - Filament Cylinder 3 (Q12)
P161C - 001 - Interruption
Error Status: 01110001
Error Priority: 0
Lost Count: 255
Odometer: 237289 km
Time: 0
Date: 2015.01.16
Time: 07:55:02
Speed: 1008 /min
Torque: 163.8 Nm
Speed: 2.2 km/h
Keypad Ratio: 1.0 %
Voltage: 13.83 V
Keypad Ratio: 21.7 %
Temperature: 4.5°C
005715 - Please retrieve error codes from the ABS control unit.
P1653 - 002 -
Error Status: 01100010
Error Priority: 0
Frequency of Errors: 8
Lost Count: 255
Mileage: 240255 km
Time: 0
Date: 2015.02.21
Time: 11:14:12
Speed: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Keypad Ratio: 1.0 %
Voltage: 11.63 V
Binary Value: 00101000
Torque: 109.2 Nm
Readiness: 0 0 0 0 0
Address 02: Transmission Label file: DRV\09L-927-760.lbl
Part Number SW: 4F2 910 156 F HW: 09L 927 156 C
Part Number: AG6 09L 3.0 TDI RdW 0030
Revision: --H01--- Serial Number: 4239565
Encoding: 0000001
Operating Number: WSC 02325 785 00200
VCID: 285B97CF9B441261067-807D
No error codes found.
Address 03: Brake Electronics Label file: DRV\4F0-910-517.lbl
Part Number SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial Number: 00000000000000
Encoding: 0020876
VCID: 66C7D9F751D0C411F4B-8033
2 error codes found:
18055 - Verify coding/variants of engine control units in the powertrain
P1647 - 000 -
Error Status: 01100000
Error Priority: 2
Frequency of Errors: 5
Lost Count: 132
Mileage: 240255 km
Time: 0
Date: 2015.02.21
Time: 13:03:42
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0014
Hex Value: 0x07AA
Hex Value: 0x00FF
01517 - Control unit for trailer detection (J345)
000 - -
Error Priority: 2
Lost Count: 132
Mileage: 240255 km
Time: 0
Date: 2015.02.21
Time: 13:03:42
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0014
Hex Value: 0x08AA
Hex Value: 0x00FF
Address 05: Access/Start Report Label file: 4F0-910-852.clb
Part Number SW: 4F0 910 852 HW: 4F0 905 852 B
Part: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial Number: 10601100553067
Encoding: 0000131
Operating Number: WSC 02323 785 00200
VCID: 63C1C0E3A2E2B139135-8036
Subsystem 1 - Part Number: 4F0 910 131 E
Part Number: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part Number: 4F0 910 220 D
Part Number: FBSAUDIC6 IDG H01 0040
1 Error found:
01176 - Key
004 - No Signal/Communication - Sporadically
Error Status: 00100100
Error Priority: 2
Frequency of Errors: 4
Lost Count: 150
Mileage: 238712 km
Time: 0
Address 07: Number of/Operating unit Label file: DRV\4F0-910-7xx-07-H.lbl
Part Number SW: 4F0 910 731 J HW: 4E0 035 729
Component: Interface Box H43 2860
Revision: 00000000 Serial Number: 350JX067723846
Encoding: 0001001
Operating Number: WSC 02335 785 00200
VCID: 295D92CB804E2B69199-807C
Subsystem 1 - Part Number: 4F0 910 609 E
Component: MMIC6H02 0060 control unit
Subsystem 2 - Serial Number: 00000000546987
Subsystem 3 - Serial Number: 0110.10.060000000100011731
Subsystem 4 - Serial Number: 011731ÿ
1 Error found:
02244 - Button in the control panel is stuck
000 - - - Sporadisch
Error Status: 00100000
Error Priority: 5
Frequency of Errors: 2
Lost Count: 171
Mileage: 240255 km
Time: 0
Date: 2015.02.21
Time: 12:21:32
Binary Value: 00000000
Binary Value: 001
Address 08: Climate/Heating Control Label file: 4F0-910-043.lbl
Part Number SW: 4F0 910 043 HW: 4F1 820 043 AC
Part Number: KLIMABETAETIGUNGH20 0170
Revision: 00000031 Serial Number: 00000000298500
Encoding: 0000278
VCID: 5BB1F8039A9289F95B5-800E
1 Error found:
01274 - Actuator for the Stamping Door (V71)
003 - Mechanical Failure - Sporadic
Error Status: 00100011
Error Priority: 3
Error Frequency: 254
Lost Count: 171
Time: 0
Date: 2015.01.15
Time: 11:13:09
Voltage: 13.50 V
Temperature: 11.0°C
(no unit): 89.0
(no unit): 196.0
Temperature: 8.0°C
Address 09: Central Electrical Label file: DRV\4F0-910-279.lbl
Part Number SW: 4F0 910 279 K HW: 4F0 907 279
Part: ILM Driver
H15 0240
Revision: 00000000 Serial Number: 4F0907279
Encoding: 0012121
VCID: 316D7AABA89E53A9D19-8064
Subsystem 1 - Part Number: 4F1 910 113 C Label file: DRV\1KX-955-119.CLB
Part: Wiper AudiC6 H05 0210
Encoding: 00064784
Subsystem 2 - Part Number: 4E0 910 557 A Label file: DRV\8K0-955-559.CLB
Component: RAIN SENSOR H13 0090
Encoding: 00146221
Address 0E: Media Player 1 Label file: DRV\4E0-910-111.lbl
Part Number SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial Number: AUZ5ZBF8204491
Operating Number: WSC 00000 000 00000
VCID: 1C33BB1FDF1CCEC192F-8049
Address 15: Airbag Label file: DRV\4F0-910-655-8R.lbl
Part Number SW: 4F0 910 655 E HW: 4F0 959 655 B
Part: 42 AIRBAG AUDI8RH29 0280
Revision: 08H29000 Seriennummer: 0037LD0H0GKB
Encoding: 0013362
Subsystem 1 - Serial Number: 6332CSME13361076V
Subsystem 2 - Serial Number: 6342CSME136A16391
Subsystem 3 - Serial Number: 6352QSME142C1F5DU
Subsystem 4 - Serial Number: 6362QSME136E441BM
Subsystem 5 - Serial Number: 63734SME144E3535/
Subsystem 6 - Serial Number: 63834SME14217A63-
Address 16: Steering Wheel Electronics Label file: DRV\4F0-910-549.lbl
Part Number SW: 4F0 910 549 HW: 4F0 953 549 A
Part: Steering column module H08 0230
Revision: 00H08000 Serial Number: 90055062810312
Encoding: 0002042
Subsystem 1 - Part Number: XXXXXXXXXXX
Part: Steering Wheel Module H07 0090
Address 17: Control Panel Insert Label file: DRV\4F0-910-xxx-17.lbl
Part Number SW: 4F0 910 930 C HW: 4F0 920 932
Component: COMBINATION INSTRUMENT M73 H18 0120
Revision: 00600000 Serial Number: 5HP37V2A6
Encoding: 2049043
Plant No.: WSC 12345 001 136936
VCID: 234180E3E262F139535-8076
Address 19: Diagnostic Interface Label file: DRV\4F0-910-468.lbl
Part Number SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial Number: 13008069150084
Encoding: ECFE73C41B3104
VCID: 275994F3965A1D190FD-8072
1 Error found:
01044 - Incorrectly coded control unit
000 - -
Error Priority: 1
Lost Count: 131
Mileage: 240255 km
Time: 0
Date: 2015.02.21
Time: 11:14:09
Address 37: Navigation Label file: DRV\4E0-910-88x-37.lbl
Part Number SW: 4E0 910 888 P HW: 4E0 919 887 D
Part: MNS ECE H48 1060
Revision: 00000000 Serial Number: 364J2067598069
VCID: 3B7158837AD2A9F97B5-806E
1 Error found:
02927 - DVD Player Errors
Error Priority: 6
Frequency of Errors: 3
Lost Count: 164
Mileage: 239242 km
Time: 0
Date: 2015.02.06
Time: 23:47:40
Hex Value: 0x54E6
Hex Value: 0x177B
Hex Value: 0x0401
Hex Value: 0x0000
Address 42: Electrical Door Driver Label file: DRV\4F0-910-793-42.lbl
Part Number SW: 4F0 910 793 E HW: 4F0 959 793 E
Part Number: TSG FA H12 0120
Revision: 00000000 Serial Number: 8p
Encoding: 0001642
Operating Number: WSC 02327 785 00200
VCID: 2C536BDF8FBC3E41E2F-8079
Address 46: Comfort System Label file: 4F0-910-289.lbl
Part Number SW: 4F0 910 289 G HW: 4F0 907 289 G
Part: Comfort Device H22 0170
Revision: 01700022 Serial Number: 01020639250000
Encoding: 0402053
VCID: 2E5761D7B9A04C51CCB-807B
Address 47: Sound System Label file: DRV\4F0-910-223-BO.lbl
Part Number SW: 4F0 910 223 F HW: 4F0 035 223 F
Part Number: DSP-High C6 H09 0190
Revision: PROD_01 Seriennummer: 00000000015576
Encoding: 0000112
VCID: 214D8AEBF87EE329419-8074
Address 4F: Central Electrical II Label file: DRV\4F0-910-280.lbl
Part Number SW: 4F0 910 280 HW: 4F0 907 280 A
Part: ILM Passenger Side H10 0080
Revision: Series Number: 00000000299719
Encoding: 0001013
VCID: 5EB7F11789809CD13CB-800B
Address 52: Rear Passenger Door Electrical Label file: DRV\4F0-910-793-52.lbl
Part Number SW: 4F0 910 793 E HW: 4F0 959 792 E
Part: TSG BF H12 0120
Revision: 00000000 Serial Number: a'
Encoding: 0001642
Address 53: Parking Brake Label file: DRV\4F0-910-801.clb
Part Number SW: 4F0 910 801 B HW: 4F0 907 801 A
Part: EPB CB4C0060 H04 0060
Revision: --H04---
Encoding: 0000321
Operating Number: WSC 02324 785 00200
Address 55: Light fixture control. Label file: DRV\8P0-907-357.lbl
Part Number: 8P0 907 357 F
Part: Dynamic LWR H02 0010
Revision: 00000001 Serial Number:
Encoding: 0000003
VCID: 3D75569B64C6A7C9451-8068
Address 56: Radio Label file: DRV\4E0-910-541.lbl
Part Number SW: 4E0 910 541 M HW: 4F0 035 541 H
Part Number: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial Number: 394J9067688838
Encoding: 0000001
VCID: 2A5F6DC785482071103-807F
Address 61: Battery Control Label file: DRV\4F0-910-181.lbl
Part Number SW: 4F0 910 181 E HW: 4F0 915 181 A
Part Number: J0644 BEM H12 0590
Revision: 00000000 Serial Number: 00000000116094
Operating Number: WSC 48950 143 68925
Subsystem 1 - Part Number: 4F0 915 105 D
Part Number: VA0 2610070726
Encoding: 344630393135313035442056413032363130303730373236
Operating Number: WSC 00000 384 00290
Address 62: Electrical door opener, right side. Label file: DRV\4F0-910-795.lbl
Part Number SW: 4F0 910 795 E HW: 4F0 959 795 E
Part Number: TSG HL H21 0050
Encoding: 0001066
Address 69: Trailer Label file: DRV\4F0-907-383.clb
Part Number SW: 4F0 907 383 D HW: 4F0 907 383 D
Part Number: J345 Towbar module 0040
Revision: 00H06000 Serial Number: 4F0907383D
Encoding: 0065536
Address 72: Electrical door, right side. Label file: DRV\4F0-910-795.lbl
Part Number SW: 4F0 910 795 E HW: 4F0 959 794 E
Part: TSG HR H21 0050
Encoding: 0001066
Address 76: Parking Assist Label file: DRV\4Fx-910-283.lbl
Part Number SW: 4F0 910 283 G HW: 4F0 919 283 G
Part Number: Parking Assist 8-Channel H12 0060
Revision: 00H12000 Serial Number: 06330626800113
Encoding: 0211116
Plant No.: WSC 12345 123 12345
Address 77: Telephone Label file: DRV\4F1-910-336.lbl
Part Number SW: 4F1 910 336 HW: 4F1 862 335
Part: BTA H09 0530
Revision: 00H09000 Serial Number: 00000007508621
Encoding: 0050011
VCID: 61CDCAEBB8FEA329019-8034
Ende----------------------------(Duration: 03:10)-----------------------------
Address 69:4F0 907 383 re-encoded (Short Encoding) from 0065536 to 0066307 (00000/000/00000)
Post22-02-2015, 18:12    Subject: Audi A6, Error after trailer hitch retrofit Quote
What does your electrical system guide say?
Best regards, Rainer
maendy
Post22-02-2015, 18:29    Subject: Audi A6, Error after trailer hitch retrofit Quote
Hello Rainer, thank you for your response,
in the E-Bausatz description (ECS) it only states: "The vehicle-side gateway must be coded by a VW dealer."
Post22-02-2015, 20:48    Subject: Audi A6, Error after trailer hitch retrofit Quote
What exactly did you enter in which tax device?
maendy
Post22-02-2015, 21:12    Subject: Audi A6, Error after trailer hitch retrofit Quote
Hello Herbert!
Actually, it's just the parking brake for trailer operation, which also works.
I wanted to add the value 16384 to the encoding in the brake electronics, as indicated in the note.
but the value was not accepted.
Otherwise nothing, unfortunately, there is no description for coding in the E-sentence.
Best regards, Maendy
Post22-02-2015, 23:06    Subject: Audi A6, Error after trailer hitch retrofit Quote
As a general rule, a newly added control unit must be activated in the gateway's list (address 19) (check the box).
This is clearly missing here, which is also why it was not detected in the initial car scan.
69-Supporters -- Status: Not registered 0001
stands.
Basic Procedure:
/viewtopic.php?t=24420
Post22-02-2015, 23:43    Subject: Audi A6, Error after trailer hitch retrofit Quote
Okay.
maendy
Post23-02-2015, 22:42    Subject: Audi A6, Error after trailer hitch retrofit Quote
Thank you for your advice, now I understand a lot better. I'll also take a look at my Passat... I'll take a closer look at everything again next weekend, since the Audi is unavailable.
Thank you again, maendy
Post24-02-2015, 9:25    Subject: Audi A6, Error after trailer hitch retrofit Quote
Just for clarity: The AHK entry appears in the Steuergeräte (control units) for engine, central electrical system, braking electronics, and diagnostics on the A4. This will likely be similar on the A6. Probably, the entries are simply missing, which is why the specific errors occur (excluding MSG).
First, disconnect the tow hitch control unit to clear all errors, then reconnect the tow hitch control unit and register it. So you can see which errors reappear.
maendy
Post27-02-2015, 10:41    Subject: Audi A6, Error after trailer hitch retrofit Quote
Hello everyone, it worked...in the central electrics, the checkmark for trailer lights was missing, and in the braking electronics, the proposed value (0016384) was added to the existing code.
Thank you again for your tips.
No new posts Audi A4 documentation, fault in the secondary air system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4: Airbag System Error - Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Audi, Fehler am Elektrolüfter Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Q5: MMI Map Update Causes EEPROM Error Electrical Systems, Vehicle Electronics, Multimedia
No new posts ABS Error After Wheel Bearing Replacement Diesel Engine Technology
No new posts Golf 6 AGR error after rodent damage Diesel Engine Technology
No new posts High Beam Error: Coding Issues & Fixes On-Board Diagnostics (OBD)
