Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot
stepnogorsk
Post24-05-2015, 13:16    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
I have an Audi A6 4F with a 2.0 BRE engine that's experiencing a problem.
"When the engine gets too hot, the glow plug warning light comes on, and this is stored in the error memory."
001031 - Potentiometer for exhaust gas recirculation (G212).
P0407 - 000 - Signal too low - Intermittent.
Freeze Frame.
Error status: 00100000
Error priority: 1.
Error frequency: 1.
Mileage: 214,000 km
Time: 0.
Date: 2015.05.08
Time: 18:09:40
Freeze Frame.
Speed: 2037 /min
Speed: 110.0 km/h
Last: 40.8%
Lambda: -4.9%
Air mass/flow rate: 1050.0 mg/H.
Air mass/dose: 1005.0 mg/H
Binary value: 00000000
Sometimes, but very rarely, something else happens as well:
01027 - Exhaust gas recirculation (EGR) valve (N18).
P0403 - 000 - Malfunction - Intermittent.
Freeze Frame.
Error priority: 1.
Error frequency: 2.
Mileage: 213,998 km
Time: 0.
Date: 2015.05.08
Time: 18:07:17
Freeze Frame.
Speed: 882 RPM
Speed: 0.0 km/h
Key press ratio: 84.4%
Voltage: 13.68 V
Air mass/Hub: 480.0 mg/H
Key press ratio: 0.0%
It started happening after I replaced the EGR valve. However, it wasn't the EGR valve that was defective; it was a different issue – the teeth on a gear had broken off.
Now it's unclear whether the new AGR (AbgasrĂźckfĂźhrung - exhaust gas recirculation) system is also defective, or if the problem lies elsewhere.
Where is the potentiometer for the exhaust gas recirculation (EGR) system located? Is it built into the EGR valve itself, or somewhere else?
And another question: I have a used AGR valve here. I tried to clean it and noticed that you can rotate the flap without the shaft turning. Is this intentional, or is this part also defective?
Thank you very much for your tips. I already asked on Motor-Talk, but I haven't received any answers yet.
PS: Sorry for my bad German, but I think it's somewhat understandable what I described icon_smile.gif.
Translated on 09-09-2026, 4:54.
Post24-05-2015, 13:59    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
Now it is unclear whether the new EGR valve is also defective, or if the problem lies elsewhere?
Where is the potentiometer for exhaust gas recirculation located? Is it inside the EGR valve itself, or somewhere else?
It looks like there's a defect... or a broken cable.
Was the replacement part an original part, or possibly cheap, low-quality junk from East Asia?
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 09-09-2026, 4:59.
stepnogorsk
Post24-05-2015, 14:09    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
I'm not entirely sure, but I think it's a replica; I bought it on eBay, and this is the part http://www.ebay.de/itm/151554678441?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT.
"The other valve is definitely original, but I'm not sure now if it's supposed to have that flap."
Translated on 09-09-2026, 5:00.
Post24-05-2015, 14:19    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
A loose flap that just flutters back and forth is non-functional. It's best to compare it to the original part.
I think there's a high chance that the item purchased from the online marketplace is defective.
stepnogorsk
Post24-05-2015, 14:57    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
Unfortunately, I no longer have the original part icon_sad.gif I foolishly threw away too quickly.
Wo ist denn eigentlich das Poti dafĂźr eingebaut? Inside the valve itself?
Looking at this, it seems like the valve is controlled from an external source.
Translated on 09-09-2026, 5:01.
stepnogorsk
Post24-05-2015, 20:30    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
Unfortunately, it's not working, and I have no idea why. It's an MP4 file and it's 40 MB in size, which should be fine, but it's not working.
It's not really interesting, as you can only see that you can rotate the flap on the axis by about 15 degrees without the axis itself rotating. And I don't know if that's supposed to be the case or not.
Edit: It actually worked, but the video was cropped, so it's even harder to see now.
Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot - 2015-05-22 13.56.43.mp4
 File size:  40.28 MB
 Viewed:  6173 times
Translated on 09-09-2026, 5:02.
Post24-05-2015, 20:55    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
"Works perfectly, thank you very much!"
And I don't know if that's supposed to be like that or not.
No, I would re-weld it in the correct position. The resting position is: closed.
Where exactly is the potentiometer installed? Is it inside the valve itself?
Yes. It's possible that it also has an inductive sensor installed. If you bought that part as shown in the video, it's quite likely to be defective.
Translated on 09-09-2026, 5:03.
stepnogorsk
Post25-05-2015, 10:30    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
Okay, thank you very much for the tips. I will let you know when I have made more progress.
Translated on 09-09-2026, 5:04.
stepnogorsk
Post28-05-2015, 20:23    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
I just got back from the workshop, and I installed a new, genuine AGR valve this time.
Drove 40 km on the highway, and the warning light came on again, and errors were stored again.
What's your next suggestion for something I should check?
Post28-05-2015, 20:40    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
Do you have any suggestions on what I should check next?
Definitely include the wiring harness with the connector for the AGR (AbgasrĂźckfĂźhrung - Exhaust Gas Recirculation).
Translated on 09-09-2026, 5:05.
stepnogorsk
Post28-05-2015, 20:57    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
Yes, as far as I could, I inspected the wiring harness (visually) and didn't find any damage.
The day before it started, I drove over a traffic island at night, quite roughly, and it made a loud noise. The next day, the warning light came on. Could it be related?
Nachtrag! Habe gerade nochmal geguckt, vielleicht lag es dieses Mal am Stecker, der war nicht richtig drauf glaube ich. Dabei habe ich gemerkt wenn Motor aus ist und ZĂźndung an summt irgendwas unter der Motorhaube ich glaube das ist der AGR selbst, ziehe ich den AGR Stecker ab, hĂśrt Summen auf. Wenn ich ZĂźndung aus mache summt es noch 2-3 Sekunden macht Klack-Klack und dann ist Ruhe. IsIs that normal?
And the plug doesn't click into place properly anymore; that small latch that secures it has broken off. Is there perhaps a trick to getting it to stay in?
Translated on 09-09-2026, 5:06.
Post29-05-2015, 10:12    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
And the plug doesn't click in properly anymore; this small latch that locks it in place has broken off. Is there perhaps a trick to get it to stay in?
It's best to replace it if the plug is available for individual purchase.
Otherwise, one or more cable ties might help you temporarily secure the plug.
You should definitely take a close look at all the connections, from the AGR to the STG.
Perhaps there are increased contact resistances somewhere in the chain or within the control unit (ECU) itself, especially when the vehicle is hot.
Translated on 09-09-2026, 5:07.
stepnogorsk
Post29-05-2015, 10:16    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
Okay, I'll try that out this afternoon. I'll let you know how it goes.
Translated on 09-09-2026, 5:08.
stepnogorsk
Post29-05-2015, 20:50    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
So icon_biggrin.gif it goes! I reinstalled the plug and that was it. Now it clicks in properly and there are no errors. I just drove 280km without any error messages!
Thank you for your tips and help.
Post29-05-2015, 21:15    Subject: Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal When Hot Quote
Great icon_smile.gif.
Translated on 09-09-2026, 5:09.
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust gas recirculation: function and problem areas Technical Articles
No new posts P0487 - Exhaust Gas Recirculation (EGR) Throttle Control ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts NOx Signal Low: Troubleshooting Guide Diesel Engine Technology
No new posts P0237 Audi A3 2.0 TDI: Low Signal Diesel Engine Technology
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
This topic is locked, you cannot edit or reply. AGR Potentiometer Check: BLS with DPF. Electrical Systems, Vehicle Electronics, Multimedia
