A3 8P 170PS CFGB --> 177PS CFGC?
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post20-03-2015, 18:59    Subject: A3 8P 170PS CFGB --> 177PS CFGC? Quote
Hello everyone,
as I have now read, the 2.0TDI CFGB and CFGC appear to be identical in hardware. Is it possible to essentially "upgrade" simply by swapping the engine control unit? I haven't found much information about this online, which is making me suspicious.
For me, however, it is also questionable whether a CFGC control unit from the A4 would work with my A3. Specifically regarding WFS and all the CAN messages from the vehicle environment.
Greetings
brezelmann01
Post20-03-2015, 19:05    Subject: A3 8P 170PS CFGB --> 177PS CFGC? Quote
{However}, it's also questionable whether a CFGC control unit from the A4 would work with my A3.
brezelmann01
Post20-03-2015, 19:19    Subject: A3 8P 170PS CFGB --> 177PS CFGC? Quote
No. Because of 30Nm. And as for the main reason: the desire to play and create. icon_cool.gif
No new posts Audi A4 8K TDI 2.0 CR: Differences between 170PS vs. 177P... Diesel Engine Technology
No new posts Passat B7 TDI: VCDS Diagnostics, No Data Blocks On-Board Diagnostics (OBD)
No new posts Clutch Pedal Switch CFGB On-Board Diagnostics (OBD)
No new posts Audi A3 8P Oil Temp Sensor CFGB Diesel Engine Technology
