Oellappen
Joined: 11/23/2014 Posts: 32 Karma: +0 / -2 Location: Berlin
24-02-2015, 23:45 Subject: Import K-Power Log Files |
Log files cannot be imported, what am I doing wrong?
Best regards, Peter.
Translated on 19-09-2026, 18:28.
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: München & Passau
25-02-2015, 1:15 Subject: Import K-Power Log Files |
Hello everyone!
Here's the translation:
"Just to let you know, I've moved your post from the "gasoline engine" section here because it doesn't have anything to do with spark ignition engines."
Please take note of this in the future, thank you.
It seems that you are increasingly unwilling to disclose any problems, even when it is obligatory.
Therefore, as in the other threads you started, the following applies:
 WHAT exactly, WHERE, did you do that it doesn't work?
Alternatively, I can say: It works for me, so do it differently/better - topic closed.
Best regards from Munich!
Translated on 19-09-2026, 18:29.
25-02-2015, 12:01 Subject: Import K-Power Log Files |
First of all, you're doing it wrong by trying to hide the non-importable log file in your pocket instead of simply attaching it as a file to your post.
Quote: | | It seems that you are increasingly unwilling to disclose any problems, even when it is obligatory. |
Because then you have to write lengthy explanations for such obvious things, and I have to extract every tiny piece of information (the informational content of your post divided by the number of characters you typed) from you with a long, drawn-out process.
No one can assess what might be wrong with a missing log file.
Translated on 19-09-2026, 18:30.
Profile PM WWW Garage |
Oellappen
25-02-2015, 22:45 Subject: Import K-Power Log Files |
Hello, here is my file.
Translated on 19-09-2026, 18:31.
25-02-2015, 22:56 Subject: Import K-Power Log Files |
Ahem.
How can you perform a performance analysis with partial load or, even worse, mostly idle operation?
Profile PM Garage |
Oellappen
25-02-2015, 23:31 Subject: Import K-Power Log Files |
Hello dieselmartin,
As I mentioned before, I'm a beginner, so I have a lot of questions and make a lot of mistakes.
I performed the measurement as instructed, but perhaps I made a mistake.
Mistakes were made.
First of all, thank you very much for your very quick response.
I would be happy to repeat the measurement run.
Translated on 19-09-2026, 18:32.
26-02-2015, 17:27 Subject: Import K-Power Log Files |
Hello Peter,
For your vehicle, it would have been sufficient (and would have been better due to the greater number of data points per unit of time) to only log data block 5 in group A (the first selection row for the data blocks).
I've attached the revised CSV file. You can import it into KPower, and you'll just need to enter the correct vehicle weight.
Future versions of KPower will change the way measurement columns are selected and, most importantly, will eliminate the need for imports when used with the correct diagnostic system.
| Description: |
| KPower Leistungsdiagramm für 1380kg, leider mit wenig Messwerten. |
| File size: |
26.64 KB |
| Viewed: |
1098 times |
| Description: |
 Download |
| File name: |
Test.CSV |
| File size: |
2.23 KB |
| Downloaded: |
316 times |
Translated on 19-09-2026, 18:33.
Oellappen
26-02-2015, 23:49 Subject: Import K-Power Log Files |
Hello Rainer, thank you very much for your quick response and good solution.
Problems.
After the test drive on the highway, it's working properly again.
Let's see how long it lasts.
Translated on 19-09-2026, 18:34.
Oellappen
22-03-2015, 16:20 Subject: Import K-Power Log Files |
Hi Rainer, I followed your advice and it worked.
Here's the result.
Translated on 19-09-2026, 18:35.
