Golf 5 1.4 TSI, BMY, Fault: Intake Valve
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post17-06-2016, 15:18    Subject: Golf 5 1.4 TSI, BMY, Fault: Intake Valve Quote
Hello everyone,
My colleague came running towards me at the end of the shift; he had a "minor" problem;
Golf 5 1.4 TSI, I mean, it's a BMY (140hp)
Error 008196 - Suction valve for airflow control Bank 1
P2004 - 000 - Open
Error reappears immediately after engine restart.
Log-Log.txt
 File name:  Log-Log.txt
 File size:  1.69 KB
 Downloaded:  1115 times
Post17-06-2016, 15:51    Subject: Golf 5 1.4 TSI, BMY, Fault: Intake Valve Quote
Hi Gremlin,
/viewtopic.php?t=28621&highlight=p2004
It refers to an error that occurs when switching between the switchgear. Especially with non-turbocharged gasoline engines, resonance induction utilizes the intake manifold to achieve a better engine filling rate.
This requires a long intake path at low speeds, and a short intake path at high speeds.
The valve you mentioned switches between short and long intake paths. Rest siehe mein Link oben.
Regarding the function of the suction pipe in your motor: Search for "SSP 359" and refer to page 48.
It would be great if you could post a picture of the valve.
Best regards, Rainer
Gremlin
Avatar-Gremlin
Post17-06-2016, 16:10    Subject: Golf 5 1.4 TSI, BMY, Fault: Intake Valve Quote
Since it's not my car, I won't have access to it again so quickly (at the earliest in week 26) - but I'll see what I can do - regarding the photo icon_cool.gif
EDIT:
If I'm not mistaken, these should be the "03C133204AJ" flaps. (Google Image Search)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3135 - Airflow Control Valve: Exceeds Limit. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P3138 - Airflow Control Valve: Control Difference Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf V Intake Manifold Flap - Airflow Control & P138 ... Diesel Engine Technology
No new posts Error - Airflow control valve for 1.9 TDI BLS Diesel Engine Technology
No new posts Error code P2015 Intake manifold flap | VW CADDY III BLS ... Diesel Engine Technology
No new posts BLS intake flap Upload
