P0420 Error: Lambda Sensor/Catalytic Converter Issue
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Gasoline Engine Technology
servusssss
Post28-12-2014, 17:01    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
Hello fellow DIY enthusiasts,
Unfortunately, the support team couldn't find any errors.
It's an Audi A3 with a 1.6L 2V engine.
It has already been exchanged.
- Oxygen sensor after catalytic converter.
- Spark plugs
- Activated carbon filter.
- Temperature sensor checked.
- The intake and exhaust systems were checked multiple times for leaks.
- Emission levels are perfectly fine.
The exact error is:
Code:
                Adresse 01: Motorelektronik       Labeldatei: RKS\06A-906-033-BGU.lbl
   Steuerger‰t-Teilenummer: 06A 906 033 EH
  Bauteil und/oder Version: SIMOS71 1.6l 2V     9429
                 Codierung: 0000071
            Betriebsnummer: WSC 06314 000 00000
                      VCID: 69DC1836401440562C3-803C
1 Fehler gefunden:
16804 - Katalysatorsystem; Bank 1
            P0420 - 006 - Wirkung zu gering - Sporadisch
             Freeze Frame:
                    Drehzahl: 3808 /min
                    Hex Wert: 0x0079
                    Geschwindigkeit: 120.6 km/h
                    Temperatur: 624.0°C
                    Drehzahl: 3808 /min
                    Hex Wert: 0x007C
                    Temperatur: 616.0°C
Unfortunately, the error is not consistent but occurs sporadically. There is no correlation with external temperature or other factors.
The solutions I found using "google" didn't necessarily help me much.
Has anyone else experienced this error?
Thank you very much for your efforts!
P.S.: I'm not really an expert on gasoline/petrol.
Translated on 23-07-2026, 13:09.
Post29-12-2014, 13:41    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
Unfortunately, the error is not constant but sporadic.
When and how often does the error occur? What is the mileage?
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 23-07-2026, 13:11.
servusssss
Post29-12-2014, 18:54    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
The error occurs every 200-400 kilometers after being cleared.
The car has 135,000 kilometers on the odometer, but it's not driven for short distances.
SG Christian.
Translated on 23-07-2026, 13:12.
Post02-01-2015, 23:08    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
Check the lambda value after the catalytic converter while driving; it might indicate that the catalytic converter is not functioning correctly anymore.
Translated on 23-07-2026, 13:13.
servusssss
Post05-01-2015, 12:45    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
I've already checked the values, but unfortunately, no error occurred during these trips.
I've now completed the readiness assessment.
The result is that a new error has been introduced.
Code:
18628 - Bank 1 Sonde 1
            P2196 - 006 - Signal zu fett
             Freeze Frame:
                    Drehzahl: 1984 /min
                    (keine Einheit): 0.99
                    Spannung: 2.040 V
                    Spannung: 0.780 V
Readiness: 0010 1101
What do you think, probe or catalytic converter?
What else can be checked?
Sure, here's the translation:
"SG" can have different meanings depending on the context. It could stand for "Spielgemeinschaft," which is a German term for a sports club or association that combines players from multiple teams or organizations. Alternatively, it could refer to "SĂ€kularkantor," a type of church musician who does not hold religious beliefs. Finally, "SG" might be an abbreviation for "Sonstige," meaning "other" or "miscellaneous."
Translated on 23-07-2026, 13:14.
Post05-01-2015, 12:54    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
T3Surfer wrote:
Check the Lambda value after the catalytic converter while driving.
servusssss wrote:
I've already looked at the values, but unfortunately, no error occurred during these trips.
You should look at the lambda value in the measurement block and see if it's running too fat.
It doesn't matter if an error is accidentally entered while you're looking at it.
Translated on 23-07-2026, 13:15.
servusssss
Post05-01-2015, 13:18    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
Hi.
You should look at the lambda value in the measurement block and see if the engine is running too rich.
I already checked the values during the ride, and I didn't notice anything unusual or any error messages.
This occurred during the readiness test.
I looked at the documents with identification numbers MWB 001-031-037; are these the correct ones?
Translated on 23-07-2026, 13:16.
Post05-01-2015, 13:28    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
Okay, just create a log file and upload it here.
Translated on 23-07-2026, 13:17.
Post05-01-2015, 13:36    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
"For vehicles with higher mileage, a P0420 code usually indicates an issue with the catalytic converter or the upstream oxygen sensor, assuming everything else is in good working order."
Here's an explanation of how you can get to the bottom of the problem.
It is important to consider both lambda sensors simultaneously. The error may not be registered immediately, but it can be easily identified by observing the trend of the lambda sensor voltage over time.
Translated on 23-07-2026, 13:18.
servusssss
Post05-01-2015, 15:41    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
Here's another log, unfortunately with a lot of partial load data.
I can't see anything, but I know very little about the Lambda regulations.
LOG-01-001-031-037.CSV
 File name:  LOG-01-001-031-037.CSV
 File size:  8.29 KB
 Downloaded:  578 times
Translated on 23-07-2026, 13:19.
Post05-01-2015, 19:51    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
It actually looks quite good, and the adjustments are also fine.
It looks like an intermittent problem.
 Lambdaregelung mit KDataScope visualisiert.
 File size:  57.16 KB
 Viewed:  5654 times
Translated on 23-07-2026, 13:20.
servusssss
dieselschrauber likes this.
Post23-05-2016, 16:09    Subject: P0420 Error: Lambda Sensor/Catalytic Converter Issue Quote
Hello everyone,
After a brief inquiry via private message, here is the unfortunately not very pleasant solution to the problem.
After replacing the catalytic converter, there was a period of calm. However, after about 3000 km, the problem reappeared.
The car was then sold to a dealer.
In summary, the error could not be resolved. icon_redface.gif Under the table, a new software solution for the MSG was recommended.
Translated on 23-07-2026, 13:21.
No new posts Seat Ibiza 6L error code 16415 - Bank 1, Sensor 1; Heater... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0420 - Catalytic converter system, Bank 1, efficiency to... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lambda Sensor Error On-Board Diagnostics (OBD)
No new posts BBY Error 17584 Lambda Sensor after Catalytic Converter Gasoline Engine Technology
No new posts Lambda-Sonde (G39)- Kurzschluß nach Plus On-Board Diagnostics (OBD)
No new posts Idee : 10cent Tuning durch nachgerĂŒstete Lambda-Sonde re... Diesel Engine Technology
