Bosch Pressure Relief Valves
milledriver
Post26-05-2015, 18:38    Subject: Bosch Pressure Relief Valves Quote
Hallo zusammen, kann mir jemand sagen was die unteren Stellen der Boschnummer bedeuten (8881541425), ob diese übereinstimmen müssen beim Tausch? (Regelventil der Hochdruckpumpe)
The Bosch service can only assign the upper numbers.
It is a 3L V6 A4 Diesel Audi with the engine code CCWA.
Best regards, Dani
 File size:  26.67 KB
 Viewed:  812 times
Post27-05-2015, 0:40    Subject: Bosch Pressure Relief Valves Quote
The Bosch number is decisive for "Bosch".
If the part is manufactured for another manufacturer (e.g., VW), its own ET number is also printed. But what does the lower number then mean? It doesn't matter either if you buy the new part from Bosch.
No new posts Bosch ABS/ESP 5.3: Basic Settings & Configuration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Error codes and possible causes for Bosch ABS Version 5.0... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bosch Engine Control Units (ECUs) Diesel Engine Technology
No new posts Bosch CP4 Roller Rocker Arm Diesel Engine Technology
No new posts Bosch VE Einpritzpumpe Diesel Engine Technology
No new posts Bosch Fahrzeugpaß ? Diesel Engine Technology
