I'm having a problem with my 2.0 TDI CR 140PS CBBF engine. Occasionally, it takes a bit longer to start when the engine is cold, and then there's white smoke. This also happens while driving until the engine is somewhat warm. Very rarely, there's also a slight hesitation when accelerating gently at low RPMs.
It only occurs when the car has been parked for more than about 5 hours, and also at warmer temperatures (above
5°C). The car has 58,000 km and was manufactured in 2010. It had a chip tuning modification approximately six months ago.
I'd like to read the injector values now. Can anyone explain to me how to do that exactly?
Thank you in advance!
