Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2557 Karma: +591 / -0 Location: bei Zwickau
28-06-2015, 19:28 Subject: T4 ACV: Smoking After Standing - Troubleshooting. |
Hello!
I have a question about my T4, ACV model, manufactured in 2001, with approximately 300,000 km on the odometer.
If it's not used for a long time, or if it's only driven for very short distances,
and then properly warmed up.
Does it initially emit blue smoke from the exhaust?
Quite clear. This is no longer the case with regular, normal use.
Once I've driven it for about 10 km and it's properly warmed up, there's nothing noticeable anymore, even when the engine is running and I'm not accelerating.
The coolant doesn't disappear at all, and the oil consumption is also very low, practically negligible.
The engine starts perfectly and seems to be functioning normally.
Does anyone have any idea what this could be?
Translated on 25-09-2026, 21:13.
Autoservice Profi-Schrauber
28-06-2015, 22:18 Subject: T4 ACV: Smoking After Standing - Troubleshooting. |
For example, turbochargers...
Translated on 25-09-2026, 21:14.
Herbert Profi-Schrauber
29-06-2015, 21:13 Subject: T4 ACV: Smoking After Standing - Troubleshooting. |
Do you think the water pump has a cold leak?
What does the blue smoke smell like? You can usually tell the difference between motor oil and diesel.
29-06-2015, 21:54 Subject: T4 ACV: Smoking After Standing - Troubleshooting. |
Yes, perhaps. For example, if oil drips from the engine into the exhaust system when the engine is off... or if oil accumulates in the exhaust system and is then burned as the temperature rises.
You just have to look around sometimes...
Translated on 25-09-2026, 21:15.
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
30-06-2015, 13:34 Subject: T4 ACV: Smoking After Standing - Troubleshooting. |
Dripping nozzles?
Profile PM Garage |
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1513 Karma: +647 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
30-06-2015, 16:06 Subject: T4 ACV: Smoking After Standing - Troubleshooting. |
Hi.
Does the engine start smoothly and run on all cylinders immediately?
At what mileage was the start of the pump operation dynamically checked and, if necessary, adjusted?
Are the valve stem seals still the originals? If so, they would be 14 years old by now, and likely hardened and/or widened.
"Both of my previous AFN engines, and also the one in the predecessor Passat 35i, would sometimes smoke excessively after periods of inactivity, despite having almost negligible oil consumption. In my summer car, after replacing the cylinder head (due to a timing belt failure) with a used head and new valve stem seals, the problem is completely gone. The oil consumption is now absolutely zero, and there's no more smoke."
Translated on 25-09-2026, 21:16.
Profile PM Garage |
01-07-2015, 20:14 Subject: T4 ACV: Smoking After Standing - Troubleshooting. |
Hello!
Thank you for the answers.
So, the engine always starts immediately and runs smoothly, like clockwork. It doesn't matter if it's hot or cold, summer or winter, or if it's been sitting for 2 months.
I haven't looked into the start of the funding process yet.
I can only perform the exhaust gas smell test in a few days, as I'm currently working on the auxiliary heater and need to replace a damaged coolant hose.
I'm not trying to fight against smoking; it doesn't bother me.
I just want to be aware of all possible options and assess them so that I can take action if there is a risk of consequential damages.
So, there's a hole in the piston, probably due to a faulty injector or something like that.
I'm not the kind of person who would take apart an old engine unnecessarily.
Translated on 25-09-2026, 21:18.
Bertil Profi-Schrauber
02-07-2015, 20:03 Subject: T4 ACV: Smoking After Standing - Troubleshooting. |
For this, I recommend Haehnlein's excellent thread:
Okay, I'm ready. Please provide the German text you want me to translate.
Translated on 25-09-2026, 21:19.
