Diagnostic Trailer Controller for PQ35 E-Vehicle
Go to page: 1, 2  Next
Jan6K
Avatar-Jan6K
Post09-08-2015, 18:34    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Hello everyone,
I'm currently considering adding a tow hitch to my Octavia 2. The mechanical part is straightforward – basically, everyone recommends the Westfalia version. When it comes to the electrical components, Westfalia is also often recommended, but there have been changes in their product range (e.g., you can no longer find anything for the part numbers listed in older manuals). Specifically, the older Westfalia electrical kits are supposedly identical to the original equipment, while the newer, simpler ones are not.
Similar things are said about Jäger's sentences. AC is generally discouraged.
I'm looking for a car with an electronic control unit (ECU) that can be easily accessed and diagnosed using VCDS, as not all ECUs are compatible.
See also: http://www.octavia-forum.de/forum/viewtopic.php?f=16&t=73890
(rear section - this is where I requested scans of those control units). Elsewhere, it is mentioned that even newer Westfalia kits may not be accessible, or only accessible when a trailer is connected.
Can anyone provide helpful information here?
It appears there isn't an original kit available (at least, the accessible lists only describe solutions that involve building the wiring harness yourself from connectors and repair wires). In the O2 forum, it's often mentioned that Skoda also retrofits using kits, for example, from Westfalia, and that there isn't an "official" electrical kit.
When you look at the electronic modules (there are many online guides available), you'll notice that the connectors on the control units are different from the originals. This means that even if you buy a cheap set of modules plus a control unit from online marketplaces, you won't be able to get it working (unless you modify the connectors to make them fit).
I don't see the retrofitting and unlocking itself as a problem; there's already been a lot written about that.
Edit:
"z.B. bei" translates to "e.g., at" or "for example, at".
http://www.kupplung.de/westfalia-anhaengerkupplung-komplettsatz-112940-05162-1.html
It is clear from the AC-E statement that it is not diagnosable.
Jan.
1Z5 CFHF / AHB H4D
Translated on 19-10-2026, 6:45.
Post09-08-2015, 19:04    Subject: E-Satz mit Diagnose: PQ35 Trailer Control Unit Quote
Jan6K wrote:
Hello everyone,
I'm currently considering adding a tow hitch to our Škoda Octavia 2.
I can understand icon_wink.gif.
"There doesn't seem to be an original sentence..."
Sure!
My Skoda dealer installed that on my 1Z5 as well.
Translated on 19-10-2026, 6:48.
Jan6K
Avatar-Jan6K
Post09-08-2015, 19:07    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Do you still have the part number?
Theoretically, I also see the problem of length... an Octavia is already quite a bit longer than even the Golf Variant. Do you know how he solved that problem?
I want to install it myself... according to the online instructions and my previous experience, it shouldn't be a problem to install it in the fuse box. The only thing is that the cables can't be too short.
Jan.
1Z5 CFHF / AHB H4D
Translated on 19-10-2026, 6:49.
Post09-08-2015, 19:59    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
No... at least not immediately comprehensible.
Theoretically, I also see a problem with the length... an Octavia is already quite a bit longer than even the Golf Variant.
Huh? (Middle Hessian question word with 2 letters icon_wink.gif)
Golf 6 Variant: 4.53
Octavia 2 Estate: 4.57
The 4 cm really don't matter.
Furthermore, the trailer hitch control module (STG) in the Octavia 2 is located in the cross-platform bracket on the left side, at the rear. Even the Golf 5/6 sedan uses the same trailer hitch control module. The wiring up to that point is the same for the entire PQ35 platform. Only from that point onwards do they differ. And there is also a 1Z5 wiring harness available.
Translated on 19-10-2026, 6:51.
Post09-08-2015, 20:08    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Sure!
There are two sentences, depending on the PR number.
EEA 600 001A for PR-1D0.
EEA 600 002 for PR-1D7.
The mechanics have the EEA 600 001 model (all-wheel drive EEA 620 001).
EDIT:
These are likely complete retrofit kits, including both mechanical and electronic components.
See: http://www.autohaus-ruediger.de/userfiles/file/Prospekte/Octavia/ZubPL_Octavia_06_2011.pdf
Translated on 19-10-2026, 6:53.
Jan6K
Avatar-Jan6K
Post09-08-2015, 20:54    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Sorry, I was mistaken about the length. I thought the limited space would result in a visibly shorter size. It might actually fit now.
Hmmm... both together would be the complete (235+275), otherwise it would be much too cheap. 235 Euros for the electric kit is a bit more than, for example, what Jäger charges, AC is even much cheaper, but it's not diagnostic-capable. However, those are 2011 prices, so it's much more expensive today icon_smile.gif.
What surprises me most about the list in your link is the identical price for the electric kit with and without pre-wiring. I thought that the pre-wiring would include the cables up to the control unit, and that only the last section, including the connector, would be missing.
Edit: At least the units I've looked at more closely so far (AC, Westfalia old and new, Jaeger) connect all the way to the fuse box and are then connected to the CAN bus lines via the vehicle's onboard network control unit.
Jan.
1Z5 CFHF / AHB H4D
Translated on 19-10-2026, 6:55.
Jan6K
Avatar-Jan6K
Post09-08-2015, 21:06    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
and one more addition:
According to
http://www.octavia-forum.de/forum/viewtopic.php?f=16&t=28914&start=315
(The above number led me to this information via Google.) EEA 600 001 is the part number for the front-wheel-drive Octavia up to August 19, 2012; after that, it's 1Z0 092 155. If I were to go with that, I would actually have to calculate the exact manufacturing date. However, "38 KW 2012" definitely means September, so it would be after that date.
The number can be found under.
http://www.automobilsalon-bellemann.de/images/Fahrzeuge/PDF/skoda/octaviacombi/Octavia_ZP_2012_10_15.pdf
as a number specifically for the clutch.
Basically, it doesn't necessarily have to be the original part... Westfalia couplings are good, and there are retrofit control units with diagnostic functions (which is exactly what my question is about, so I'm wondering if anyone has any recent experiences with those).
Jan.
1Z5 CFHF / AHB H4D
Translated on 19-10-2026, 6:57.
Post09-08-2015, 21:27    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Jan6K wrote:
... Westfalia couplings are known to be good, and there are retrofit control units with diagnostic functions available (which is exactly what my question is about, so I'm wondering if anyone has any recent experiences with those).
Only for the G5 Limo... is not completely diagnostic.
You can access it through the diagnostic system, but you won't be able to read any error codes from it. It would be surprising if that worked with original equipment (OE) parts.
That's enough... it doesn't need anything more.
By the way, with the trailer ESP brake system, only the original interface box will work.
Translated on 19-10-2026, 6:59.
Jan6K
Avatar-Jan6K
Post10-08-2015, 7:56    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Hi Bertil,
Thank you for your patience... here are some follow-up questions:
Are you sure about that?
The VCDS excerpts posted here suggest the opposite.
Most of them have the original part number, so they seem to be relabeled original devices, but one person also says that they can read error codes despite the part number 000... Some (like the Jaeger part in that thread) don't even respond. Or were you referring to something else?
Are you referring to trailer stabilization? Does that mean that Rameder (kupplung.de) is saying something untrue here?
"Quote:"
Towing stabilization support: Yes.
Jan.
1Z5 CFHF / AHB H4D
Translated on 19-10-2026, 7:01.
Post10-08-2015, 16:15    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Yes!
At least, that was the case at the time of the 1Z's production. It might look different after the production run ends. I didn't think about that.
Most of them have the original part number, so they appear to be relabeled original devices, but one person also claims that they can read error codes despite the part number starting with "000...".
Relabeled original parts should not be available on the open market during ongoing production (see above). Of course, they are still diagnosable, even if they have been relabeled. Part number 000... should not be possible. This surprises me a bit.
If they are truly original parts that have been relabeled, then the trailer stabilization system would also be affected (although the TÜV [German technical inspection authority] doesn't recognize it anyway, since it's not a standard feature... and that's also noted in the vehicle registration document: "Only if the tow hitch is a standard feature").
Translated on 19-10-2026, 7:03.
Jan6K
Avatar-Jan6K
Post10-08-2015, 17:21    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Relabeled original parts should not be available on the open market during ongoing production (see above). Of course, they are still diagnosable, even if they have been relabeled. TNR 000... should not be possible. This surprises me a bit.
Hmm... the Octiforum actually provides quite detailed information about this - the older Westfalia E-kit devices are identical to the original. The explanation given is that the original was manufactured by Westfalia, so these are just different brands. However, I haven't personally seen this myself.
Since I'm not in a hurry, I'll just email Jaeger and Westfalia and ask about diagnostic capabilities and trailer stabilization.
I understand that it doesn't "officially" exist - I followed your research on that back then. I'm fine with it as long as it works icon_smile.gif. I don't consider it a safety-critical issue that it's not original, because the ESP control unit won't receive any operating data (of any kind) from the trailer, but only a signal indicating "a trailer is attached."
You can immediately tell whether the function is working or not when the trailer is connected, simply by observing the behavior of the indicator LEDs (as stated in the user manual).
Jan.
1Z5 CFHF / AHB H4D
Translated on 19-10-2026, 7:06.
Post10-08-2015, 18:40    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Jan6K wrote:
... It was explained that the original was manufactured by Westfalia...
That's not true!
The original part from Skoda is not made by Westfalia.
Neither the auxiliary heating system (AHK) nor the electrical kit in the Skoda are manufactured by Westfalia, even though this is often (incorrectly) claimed.
At VW, it's different; that's the original from Westfalia.
Translated on 19-10-2026, 7:08.
Post10-08-2015, 19:37    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Is there an original retrofit kit available from Skoda? And if so, what would be the disadvantages?
Translated on 19-10-2026, 7:09.
Post10-08-2015, 19:46    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
Herbert wrote:
Does Skoda offer an original retrofit kit? And if so, what would be the disadvantages?
Yes, see above in the thread.
I think the price will be the "problem" icon_wink.gif.
Jan6K
Avatar-Jan6K
Post10-08-2015, 22:54    Subject: Diagnostic Trailer Controller for PQ35 E-Vehicle Quote
The price isn't the only problem; there are other uncertainties. In the Octavia forum, it was reported that a dealer installed a tow hitch using a similar kit for a lot of money, and the main issue was that it only consisted of cables that then had to be assembled (crimping connectors, populating connector housings, etc.). The retrofit kits from Westfalia, AC, and Jäger are designed so that while you still need to repin three pins, the rest is essentially simple and well-documented plug-and-play.
I still want to investigate whether there's any truth to that, or if it's just a legend. Usually, that phrase is intended for the "friendly" player to use.
If the original part is "reasonably" more expensive than the alternatives, and the installation is equally complex, then that's acceptable to me. However, if it's significantly more expensive and requires significantly more effort, then it's not economically viable.
That's precisely the purpose of this thread – to share experiences with the various alternatives. The scans posted in the linked thread clearly show that there are solutions that either include the original control unit or at least one that registers with the same part numbers in the same way. In principle, this is quite possible – a manufacturer could actually combine the original control unit with its own wiring harness and offer it. That wouldn't be "rebranding" in the sense we discussed earlier.
Neither the AHK (trailer hitch) nor the electrical kit for the Skoda are from Westfalia, even though this is always (falsely) claimed.
At least, in the Octavia forum, the original tow hitch is always attributed to a Czech manufacturer. The design (a detachable tow hitch that is inserted from below) is similar to that of Westfalia, and there are supposedly no significant differences in quality. Therefore, regarding the mechanical part, I only see the question of "original or Westfalia"... I have already dismissed the other, mostly cheaper alternatives.
Jan.
1Z5 CFHF / AHB H4D
Translated on 19-10-2026, 7:11.
Post11-08-2015, 19:53    Subject: Best German Shepherd Breeders: Find Yours Now! Quote
Okay, so... the Westfalia wiring harness for the G5 from my brother was complete. Only the CAN bus needed to be accessed, and the trailer control unit (TCU) had to be connected in between (requiring rewiring at the relay panel).
The assembly was okay.
I can't say anything about the Skoda system; my dealer installed it. At least, the wiring harnesses don't look like they were self-assembled.
"Get both from Westfalia; you can't go wrong with them. That's at least my experience with the G5."
Translated on 19-10-2026, 7:14.
No new posts Trailer Control Module Not Responding On-Board Diagnostics (OBD)
No new posts PQ35 Underbody Protection Transmission, Chassis, Body & Interior
No new posts Roof Rail Clamp Tightening Torque 1Z (or other PQ35) Transmission, Chassis, Body & Interior
No new posts I am looking for an installation manual for an electric t... Diesel Engine Technology
