Boost Control Valve: Limit Charge Pressure
klopfer
2007 Audi A4 Avant
Post10-05-2003, 12:09    Subject: Boost Control Valve: Limit Charge Pressure Quote
"On the magnetic valve for boost pressure limitation, there are two hose connections and an electrical connector on the top. However, one of the two hose connections (located in the center of the valve) doesn't have a hose attached?! Can anyone tell me if a hose is supposed to be connected there, and if so, where it should lead to?"
Thank you and best regards.
Thomas.
Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
Translated on 01-10-2026, 14:10.
roter_Korsar
Post10-05-2003, 12:33    Subject: Boost Control Valve: Limit Charge Pressure Quote
Do some research here.
http://www.dieselschrauber.de/tdischlauch.html
Best regards from Bielefeld.
Peter.
Translated on 01-10-2026, 14:11.
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Magnetic valve for charging pressure regulation Diesel Engine Technology
This topic is locked, you cannot edit or reply. Boost Control Solenoid Valve Diesel Engine Technology
No new posts Boost Pressure Limiter: Explained & Benefits On-Board Diagnostics (OBD)
No new posts Boost Pressure Problems: N75 & Manifold Pressure Sensor Diesel Engine Technology
