Electrical Access Control: Configuration & Setup
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
haithamina
Post14-07-2015, 17:55    Subject: Electrical Access Control: Configuration & Setup Quote
I was able to enter the access permission, 31347, which was displayed to me by VCDS, into the central electrical system, and it was accepted.
If I want to activate features like automatic closing of the trunk or automatic lowering of the mirrors when reversing, or automatic closing via the horn, I receive the message "This service is not supported in this session."
Even completely exiting the program and re-accepting the access permissions does not change this.
What can I do about that?
haithamina
Translated on 13-09-2026, 22:44.
Post14-07-2015, 19:03    Subject: Electrical Access Control: Configuration & Setup Quote
Perhaps a diagnostic scan and some information about the vehicle icon_wink.gif would be helpful.
*Nichts ist einfacher, als sich schwierig auszudrĂŒcken......*
Translated on 13-09-2026, 22:45.
haithamina
Post14-07-2015, 21:00    Subject: Electrical Access Control: Configuration & Setup Quote
Ah, yes, sorry, it's about the B8 ID signature.
Here's the car scan:
Tuesday, July 14, 2015, 20:11:47:28160
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: RKS 14.10.2.0
Data as of: 20150412.
Vehicle Identification Number: WVWZZZ3CZFE499*** Vehicle Registration Plate:
Mileage: 6693. Repair order:
Vehicle type: 3C (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69 95
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
05-Access/Startup Report -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
13-meter distance rule -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
2B steering column lock. -- Status: OK 0000.
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000.
5F-Information Selection. I -- Status: OK 0000
69 followers -- Status: OK 0000
95-Brake electronics -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module (J623-CRLB)
Label file: DRV\04L-907-309-V1.clb
Part number SW: 04L 906 026 AS, HW: 04L 907 309 R.
Component: R4 2.0L EDC H21 1147
Revision: B5H21---
Encoding: 0119001A04541D083000
Operating number: WSC 05311 115 00301
ASAM Dataset: EV_ECM20TDI01104L906026AS 001006
ROD: EV_ECM20TDI01104L906026AS.rod
VCID: 7BF2648DF28B60F93BD-802E
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics (J104)
Label file: DRV\5Q0-907-379.clb
Part number SW: 3Q0 907 379 Q, HW: 3Q0 907 379 F.
Component: ESC H42 0610
Revision: 00000000 Serial Number: 60865000004744
Encoding: 0FEC6A8F34290B750777060441CA49F0562CD0E0608292F11460F078C002
Operating number: WSC 00015 115 00001
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 4898CB41F3DDFB61E6F-801D
Address 05: Access/Startup Authorization (J518)
Label file: None
Part number SW: 3Q0 959 435 Hardware number: 3Q0 959 435
Part number: VWKESSYMQB 023 0524
Revision: 00023000 Serial Number: 0363675890
Encoding: 000F0F0603
ASAM Dataset: EV_KessyHellaMQBAB 004027
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 77FA78BDCEA344995F5-8022
Address 08: Climate Control/Heating Unit (J255)
Label file: 5G0-907-044.clb
Part number SW: 5G0 907 044 AM, Hardware: 5G0 907 044 AM.
Component: Climatronic
Part number: H03 1001
Revision: 00001K10
Encoding: 12020124204101012015500000101802
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_VW37.rod
VCID: 72EC49A9A5C121B168B-8027
Slave 1:
Address 09: Central Electronics (J519)
Label file: 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 086 BD, Hardware: 5Q0 937 086 BD.
Part: BCM PQ37BOSCH 028 0146
Revision: -------- Serial Number: 86581903152474
Encoding: 00D38A46C24102FF4BC44004001407281C80000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 014004
ROD: EV_BCMBOSCH_VW37.rod
VCID: 7DF66A95EC9F6EC9059-8028
Slave 1:
Subsystem 1 - Part number SW: 3G1 955 119 A, HW: 3G1 955 119.
Component: WWS 150322 042 0607
Serial number: 150327175911
Encoding: 0E4DDD
Slave 2:
Subsystem 2 - Part number SW: 5Q0 955 547 A, HW: 5Q0 955 547 A, Label file: DRV\5Q0-955-547.CLB.
Component: RLHS 037 0059
Serial number: S2Y15M04D07H06M27S37
Encoding: 90A8DD
Slave 3:
Subsystem 3 - Part number SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB, Part Number: H01 0032.
Serial number: 24 01 2015 00000349
Subsystem 7 - Part number SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101.
Serial number: ESE0012918
Subsystem 8 - Part number SW: 3G0 963 345, HW: 3G0 963 345.
Serial number: ESE0016259
Subsystem 9 - Part number SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0013604
Subsystem 10 - Part number SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0016274
Address 10: Parking Assist 2 (J446)
Label file: 5Q0-919-294.clb
Part number SW: 5Q0 919 294 H, HW: 5Q0 919 294 A.
Part: PARKING ASSIST 8K H03 0053
Revision: -------- Serial Number: 39391507802076
Encoding: 0071051101
Operating number: WSC 05311 115 00060
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000.rod
VCID: 4088D361DBEDC3212EF-8015
Address 13: Distance Control (J428)
Label file: None.
Part number SW: 3Q0 907 572 A, Hardware: 3Q0 907 572 A.
Part: ACC BOSCH MQB H04 0130
Encoding: 2A40608910FFC428949C804C
ASAM Dataset: EV_ACCBOSCHVW48X 001007
ROD: EV_ACCBOSCHVW48X_VW48.rod
VCID: 33628CAD9A5B68B9A3D-8066
Address 15: Airbag (J234)
Label file: 5Q0-959-655.clb
Part number SW: 3Q0 959 655 AF, HW: 3Q0 959 655 AF.
Part: Airbag VW20, Part Number: 012 0195.
Revision: -------- Serial Number: 003R2P5VRC9C
Encoding: 98FCC0C0008000005C5400CC000800000065
Operating number: WSC 05314 000 00001
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X_VW48.rod
VCID: 020C19699561113178B-8057
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 454 002 203 15
Component: SideSensor_Df 008 0887
Serial number: 3576U000000799D8731M
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: ----------- HW: 454 002 203 15
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000D69D8731Q
Encoding: 2D2D2D
Rear side airbag crash sensor (driver's side).
Subsystem 3 - Part number: SW: ----------- HW: 454 802 403 15
Component: SideSensor_Dr 111 0148
Serial number: 3516RB2E249060000004
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 454 802 503 15
Component: SideSensor_Pr 111 0148
Serial number: 3526R09ED4906000000C
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: ----------- HW: 454 801 303 15
Component: FrontSensor_D, Part Number: 114 0149.
Serial number: 3556V06C3FF05000000K
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J524)
Label file: None.
Part number SW: 3Q0 953 521 P, HW: 5Q0 953 569 A.
Component: Steering module 075 0175.
Revision: FF032032 Serial number: 20150325401062
Encoding: 0400
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3D76AA95AC1FAEC9459-8068
Address 17: Terminal block (J285)
Label file: None
Part number SW: 3G0 920 751 Hardware: 3G0 920 751
Part: KOMBI 308 4311
Encoding: 07A409102F80000800882A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
ROD: EV_DashBoardVDDMQBAB_SE25.rod
VCID: 62CC39E97521B13118B-8037
Address 18: Auxiliary Heater (J364)
Label file: DRV\5Q0-963-272.clb
Part number SW: 5Q0 963 272 C. Hardware: 5Q0 963 272 C.
Part: STH-MQB 006 0069
Encoding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002014
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 3664B5B989297D91843-8063
Subsystem 1 - Part number SW: 5Q0 963 513, HW: 5Q0 963 513.
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001108881
Address 19: Diagnostic Interface (J533)
Label file: DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 AC
Part number HW: 5Q0 907 530 M
Component: GW MQB High, Part Number: 212 2203.
Revision: -------- Serial Number: 25031510802333
Encoding: 0B0300344F017300EF000258080F00010001070000000000000000000000
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_VW37.rod
Generator:
Control unit for multifunction device:
Subsystem 2 - Part number SW: 5G0 959 442 K, HW: 5G0 959 442 K.
Component: E221__MFL-DC1 H16 0040
Serial number: 38150000019460065132.
Encoding: 2CFFFF
Battery monitoring control unit:
Subsystem 3 - Part number SW: 3Q0 915 181 A, HW: 3Q0 915 181 A.
Part: J367-BDM, Hella, H04 8050.
Serial number: 0758495903
Inverter for wall outlet:
Subsystem 4 - Part number SW: 5Q0 907 155 C, HW: 5Q0 907 155 C.
Component: RECTIFIER H54 0033
Serial number: 0054833
Subsystem 5 - Part number SW: 3G0 919 204 C, HW: 3G0 919 204 C.
Component: Analog clock 209 2002.
Address 2B: Steering column lock. (J764)
Label file: DRV\5Q0-905-861.clb
Part number SW: 3Q0 905 861 Hardware: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000057321010
Encoding: 0000000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71EE46A5A0C71AA9911-8024
Address 42: Door Electric Driver (J386) Label file: None.
Part number SW: 5Q0 959 593 D, HW: 5Q0 959 593 B.
Component: TSG FS 020 0028
Serial number: 280115BAR00153
Encoding: 003F0B208000020000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 428CD969D5E1D13138B-8017
Address 44: Steering Assist (J500)
Label file: None.
Part number SW: 5Q0 909 143 K, HW: 5Q0 909 143 E.
Component: MQB_PP_APA 203 2033
Revision: 00000000 Serial Number: 0000187803
Encoding: 01000010005001
Operating number: WSC 00015 115 00301
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_VW37.rod
VCID: 3B72A48DB20BA0F97BD-806E
Address 52: Door electronics, passenger side (J387) Label file: None.
Part number SW: 5Q0 959 592 D. Part number HW: 5Q0 959 592 B.
Component: TSG BFS 020 0028
Serial number: 210315BCK02239
Encoding: 003F01208000020000001000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 418ED665D0E7CA29211-8014
Address 55: Headlight range adjustment (J431) Label file: DRV\5Q0-907-357.clb
Part number SW: 5Q0 907 357, HW: 6R0 907 357 A.
Component: LWR-ECU 005 0080
Revision: -------- Serial Number: --------------
Encoding: 03DA000009000000
Operating number: WSC 05311 000 00001
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
VCID: 75E672B5D4AF36894D9-8020
Address 5F: Information Selection. I (J794)
Label file: None.
Part number SW: 3Q0 035 820 Hardware: 3Q0 035 820
Component: MU-S-D-ER H11 0138
Serial number: VWZAZ2R0094041
Encoding: 02840200FF00000011111201000808001F0100840120010001
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_SK35.rod
VCID: 66C425F99909CD11F43-8033
Media Player 1:
Subsystem 1 - Part number SW: 3G0 919 605, HW: 3G0 919 605.
Component: ABT_Std-2 H44 1017
Serial number: VWZ8Z9RD500MWU
Address 69: Trailer (J345) Label file: DRV\5Q0-907-383.clb
Part number SW: 5Q0 907 383 D. Part number HW: 5Q0 907 383 D.
Component: Trailer H14 0137
Revision: 8A001001
Serial number: 0362199547
Encoding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella.rod
VCID: 3878BB81833D8BE196F-806D
Address 95: Brake electronics.
unavailable
End----------------------------(Duration: 05:21)-----------------------------
I hope this helps.
I tried oG again. I'm still getting the error message "Service not supported in this session."
haithamina
Translated on 13-09-2026, 23:23.
Post15-07-2015, 15:49    Subject: Electrical Access Control: Configuration & Setup Quote
In your case, Ross-Tech recommends trying Beta version 15.6.0 (your car is very new).
http://www.ross-tech.com/vcds/download/beta/current.php
Translated on 13-09-2026, 23:24.
haithamina
Post15-07-2015, 18:56    Subject: Electrical Access Control: Configuration & Setup Quote
Hello Rainer,
After the download, the HEX interface needed to be updated to version 1.94, which was not a problem.
The attempt to activate the automatic lowering of the mirrors when reversing resulted in the message "Service not supported in active session."
Unfortunately, it's not possible again.
haithamina
Post15-07-2015, 19:20    Subject: Electrical Access Control: Configuration & Setup Quote
Too bad...
Translated on 13-09-2026, 23:25.
haithamina
Post15-07-2015, 21:00    Subject: Electrical Access Control: Configuration & Setup Quote
Yes!
Does this mean that VCDS is not capable of adapting these features, and that I have to go to the dealership, who may not even know what to do?
That wasn't actually my plan...
Is there no solution?
haithamina
Post15-07-2015, 21:10    Subject: Electrical Access Control: Configuration & Setup Quote
According to https://community.dieselschrauber.org/en/viewtopic.php?t=2494&highlight=fahrgestellnummer.
Is your Passat model year 2015 with 6693 km on it?
Translated on 13-09-2026, 23:26.
haithamina
Post15-07-2015, 21:29    Subject: Electrical Access Control: Configuration & Setup Quote
Okay, it's tough. Features like automatic window closing, automatic rearview mirror dimming, and the horn sounding when the central locking engages are nice. Especially the latter, although it's trivial, can be incredibly helpful in stressful situations or for people with dementia.
I am waiting for the official release of version 15.6.0 or the successor to version 14.10.2.
haithamina
Translated on 13-09-2026, 23:27.
Post17-07-2015, 8:49    Subject: Electrical Access Control: Configuration & Setup Quote
Check if you can activate a development test mode in the STG 09, either through adaptation or possibly through coding.
Der Zugriffscode (31347) muß auch nicht unbedingt das Nonplusultra sein. Möglicherweise ist damit noch einiges blockiert. Kannst Du damit ĂŒberhaupt was Ă€ndern? VerPlease search for 20113.
haithamina
Post17-07-2015, 18:01    Subject: Electrical Access Control: Configuration & Setup Quote
The code 31347 originates from VCDS or the window that appears when I hover the cursor over it.
I believe I managed to activate the fuel tank lid locking mechanism while driving. However, I don't want to claim that definitively, as this issue isn't particularly important to me, and I don't recall exactly whether the feature was already set to "active."
In the motortalk online forum, the feature "automatic mirror lowering when reversing" is described as being programmable. The automatic closing of the sunroof is only available up to the 2014 model year (is this even available on the B8?). Various other features depend on the installed hardware and control units.
Ich probiere mal den vorgeschlagenen Code. Thank you.
Haithamina.
Translated on 13-09-2026, 23:29.
Post03-08-2015, 14:47    Subject: Electrical Access Control: Configuration & Setup Quote
Please test VCDS version 15.7!
https://shop.dieselschrauber.de/support-downloads.php
haithamina
Post25-08-2015, 8:12    Subject: Electrical Access Control: Configuration & Setup Quote
Good morning.
Version 15.7 now allows you to activate features such as "acoustic feedback when locking," "automatic trunk closing," or "automatic mirror adjustment when reversing." The activation will also remain active the following day.
Unfortunately, there's no sound when locking, and the mirror remains in its normal position. I haven't checked the sunroof yet.
It's strange because I can manually and electrically lower the mirrors, and I have a "horn" (presumably a parking sensor). I'm not sure if I have the "simple horn" version. I believe that in the 3BG model, the locking horn sound didn't come from the front "horn," but rather from one installed in the rear.
haithamina
Translated on 13-09-2026, 23:30.
benschke likes this.
Post25-08-2015, 14:48    Subject: Electrical Access Control: Configuration & Setup Quote
I don't know how it is with the B8. You can find some information about the B6 on the Passat forum or possibly on Alex's website (www.passat3c.info).
I haven't tried either of those things with my 3C, but as far as I remember, the following limitations apply:
- Mirror adjustment: It must have the "Memory" function installed (or its potentiometer) so that the mirror knows its position and can return to its original position.
- Acoustic alarm system: This system triggers via the alarm horn. This means that the battery-powered siren of the DWA (device) must be installed.
However, neither of these comes with any guarantee regarding the B6 model, and even less so for the B8 model.
Greetings.
Guste.
Translated on 13-09-2026, 23:32.
olli
Karma: +46 / -0   Thank you, like it!
Post25-08-2015, 14:55    Subject: Electrical Access Control: Configuration & Setup Quote
The Hupton locking system likely only works with the DWA horn.
Regarding the mirror adjustment, try setting the mirror adjustment knob to the passenger side mirror before shifting into reverse. Something might move then. This is at least how it works in the 4F model, although it's not very precise. It only works with the memory function.
Best regards from Berlin.
olli
A6 CANA/JME /
'95 Cinquecento als Stadtgurke ~~ 124CS0 fĂŒr den Sommer...
Ex-A6 AEL
Translated on 13-09-2026, 23:33.
haithamina
Post25-08-2015, 22:32    Subject: Electrical Access Control: Configuration & Setup Quote
Hello.
ich fand nun im Display / Car Setup MenĂŒ einen neuen MenĂŒpunkt: "Akustisches Warnsignal", den ich ebenfalls (per Touchscreen onboard) auf aktiv setzte und nun hupt die Kiste brav beim Verriegeln! D"as" is great!
I activated all the adaptations with acoustic warning signals in the central electronics using VCDS.
The new menu item may originate from the adaptation option "...global".
Let's see if this happens with the Spiegel as well. So far, nothing happens when reversing, regardless of whether the switch is in the "Driver" or "Passenger" position.
haithamina
Translated on 13-09-2026, 23:34.
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N3: Central Electric System Draws 120mA Idle Current Electrical Systems, Vehicle Electronics, Multimedia
No new posts Access permission, radial dampening On-Board Diagnostics (OBD)
No new posts ECU Access: BKD Engine Control Unit (EDC16) On-Board Diagnostics (OBD)
No new posts No access permission to diagnostic interface 019 on Golf 8 On-Board Diagnostics (OBD)
