Ash mass - what happens if the DPF is full?
matt
Post04-11-2015, 17:54    Subject: Ash mass - what happens if the DPF is full? Quote
Therefore, based on calculations, a value of 70 g would be achieved at 250,000 km.
What actually happens when the 70g threshold is reached?
Okay, one more addition:
1) By observing the value 'Particulate filter; OE mass', one could clearly demonstrate that the 'Dieselgate update' causes such a significant increase in soot emissions that it means 'more work' for the DPF.
2) Does the engine control unit store any data from which the frequency of regenerations can be determined, and thus the average distance between two regenerations?
Karma: +807 / -0   Thank you, like it!
Post04-11-2015, 19:54    Subject: Ash mass - what happens if the DPF is full? Quote
So, was passiert eigentlich, wenn die 70 Gramm erreicht wurden?
Hypothesis: The DPF warning light will appear...
1) By observing the value "Particulate filter; oil ash mass", one could clearly demonstrate that the "Dieselgate update" causes such a significant increase in soot emissions that it means "more work" for the DPF.
Since the value is only increasing very slowly and, in addition, the additional ash resulting from more frequent regenerations or increased consumption leads to faster ash(!!! Ashes ≠ Smoke) The filling material, therefore, would require a very long breath.
2) Does the engine control unit store any data from which the frequency of regenerations and thus the average distance between two regenerations can be determined?
However, in the measurement blocks, for example, you will find the value "Kilometer since last regeneration". But it is also only conditionally meaningful.
In principle, the amount of ash produced is proportional to the amount of fuel/engine oil that is burned, as well as the quality of the fuel/engine oil (i.e., the amount of non-combustible residue that is produced). Whether this results in 1x (little soot per km) or 10x (a lot of soot per km) after 1000km is initially irrelevant:
The DPF doesn't really care whether the ash particles are already present in the engine during combustion or only form during the soot burning process in the DPF.
Best regards, Rainer
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia I 1999 - Front wipers only work when it's dry General Tips
No new posts Check Valve Failure: Symptoms and Repair Diesel Engine Technology
No new posts What exactly happens when G11 and G12 are mixed? Diesel Engine Technology
No new posts LMM Signal vs. Fixed Value: What Happens? Diesel Engine Technology
No new posts What happens at 2000 km? Diesel Engine Technology
