Car won't start, key works? (BKD)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
yaya
Post09-11-2015, 14:48    Subject: Car won't start, key works? (BKD) Quote
Hi everyone,
Amazing phenomenon: When I turn the ignition key back out, the engine keeps running. I had the key in my hand last and realized the car was still running. The only option seems to be to stall the engine, which I don't really like doing in the long run.
I have a feeling it might be related to the ignition switch, but I'm not entirely sure whether it's an electrical or mechanical issue. Does anyone have more experience with that?
VCDS log will be added later.
Yasin.
Translated on 29-10-2026, 19:34.
Post09-11-2015, 15:10    Subject: Car won't start, key works? (BKD) Quote
What vehicle, what year of manufacture?
Generally, a modern diesel engine with an engine control unit (ECU) requires a supply voltage to continue running, unless it is burning its own oil (e.g., due to turbocharger damage). Only older, purely mechanical diesel engines could continue running without voltage if the shut-off valve in the electronic stability program (ESP) was stuck.
That means the MSG (Main System Module) seems to be still receiving power. Whether it's due to a stuck relay or a faulty ignition switch, that needs to be investigated. However, disconnecting the battery won't change either of those issues. This means that even after disconnecting the battery, there should still be voltage at the MSG and a corresponding current flow, which should quickly drain the battery.
What about other consumer devices like the instrument cluster, etc.: Do they turn off after the key is removed?
I'm looking forward to the car scan.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 29-10-2026, 19:36.
yaya
Post09-11-2015, 15:24    Subject: Car won't start, key works? (BKD) Quote
Oh, sorry - here are the details:
Golf 5
Manufactured in 2004.
Engine BKD.
Refurbishment to 30-byte Highline (but that was over 1.5 years ago).
When I remove the key, the combination instrument dims to approximately 50%.
The remaining power consumption continues even after the key is removed from the ignition (e.g., radio, subwoofer with remote control, ventilation).
When I bring the car to a stop (by shifting into 6th gear and releasing the clutch while braking), I experience the same phenomenon as when I normally park the car. Also, the "coming home" feature runs its timer and then turns off.
It has been like this for two days now - I think it's less likely that the battery is being drained (we hope so, at least icon_cry.gif).
I'm also curious to see what the log reveals.
Translated on 29-10-2026, 19:38.
jarobaldu
Karma: +40 / -0   Thank you, like it!
Post09-11-2015, 22:13    Subject: Car won't start, key works? (BKD) Quote
A few weeks ago, I had a problem with my Seat: the relay 109 was stuck.
Very rarely did the engine stall, but later on, starting problems began to occur.
Tap the corresponding relay.
Adrian.
AUDI A6 C4 1995 ABC/CRD
Fiat 124 Spider, Bj. 80
Translated on 29-10-2026, 19:39.
dieselschrauber likes this.
Post09-11-2015, 23:40    Subject: Car won't start, key works? (BKD) Quote
I would remove the casing, then disconnect the cable from the ignition switch and see what happens.
Translated on 29-10-2026, 19:40.
yaya
Post10-11-2015, 12:58    Subject: Car won't start, key works? (BKD) Quote
Okay, here are three log files (see description).
These were created as follows.
1) Read for the first time since the error occurred.
2) Errors cleared, engine started and stopped (yes, that worked), and then data was read.
3) Error code read after approximately 70 km of driving.
The errors for missing tail lights can be ignored (this is due to the conversion to 30-byte format).
After I cleared all the errors last night, I was able to start and turn off the car normally. This morning, I drove to work, and upon arrival, I saw the same error again - hence the third log file.
I'm curious to see what your opinions are.
EDIT:
@AdrianViewing profile: Adrian - Thanks for the tip, I can definitely see that, since almost all the errors are listed as "SPORADIC." A relay malfunction would explain that to me.
EDIT2:
To Adrian again: Relay 109 has already been replaced before (see /viewtopic.php?p=218380).
I could still try to force the old one back in.
Log-WVWZZZ1KZ5-268690km.txt
1)
 File name:  Log-WVWZZZ1KZ5-268690km.txt
 File size:  12.72 KB
 Downloaded:  526 times
Log-NACHER-WVWZZZ1KZ5-268690km.txt
2)
 File name:  Log-NACHER-WVWZZZ1KZ5-268690km.txt
 File size:  8.54 KB
 Downloaded:  357 times
Log-AKTUELL-WVWZZZ1KZ5-268760km.txt
3)
 File name:  Log-AKTUELL-WVWZZZ1KZ5-268760km.txt
 File size:  11.88 KB
 Downloaded:  620 times
Translated on 29-10-2026, 19:42.
Post11-11-2015, 9:16    Subject: Car won't start, key works? (BKD) Quote
jarobaldu wrote:
I had this problem a few weeks ago in my Seat: Relay 109 was stuck.
Very rarely, the engine did not turn off.
I initially considered that as well, but if the 109 is connected, then the other appliances (lights, ventilation, etc.) should still turn off. However, that's not what's happening with this particular device. How was it for you?
Translated on 29-10-2026, 19:44.
Post11-11-2015, 17:25    Subject: Car won't start, key works? (BKD) Quote
A Golf V shouldn't have a 1.09-liter engine anymore, or am I mistaken?
yaya
Post13-11-2015, 10:04    Subject: Car won't start, key works? (BKD) Quote
The Golf 5 still has that relay.
Unfortunately, I haven't had a chance to continue the analysis yet - I expect to do that on Sunday.
Currently, the "Exhaust System" warning light is still on (I think it's related to a malfunction in the intake manifold control valve).
My upcoming analysis steps:
- Check all fuses.
- Disconnect the battery for 30 minutes and then reconnect it.
Do you have any other ideas?
Translated on 29-10-2026, 19:45.
yaya
Post16-11-2015, 15:29    Subject: Car won't start, key works? (BKD) Quote
So... I've completed my initial analysis.
My idea: Throttle valve. I disconnected it, and the behavior is the same.
- All the fuses are okay.
- The battery was disconnected for 30 minutes, and the vehicle was started and stopped several times - without any issues. However, as soon as I drive a few kilometers, the problem reappears.
Regarding disconnecting the ignition switch:
- When exactly should I connect it? (With the engine running, or beforehand? --> Surely not beforehand, right? Keyword: immobilizer...)
- Where exactly should I connect it? As far as I can see, everything is connected to the steering column control unit.
Therefore, my next theory is:
Could it be that my steering column control unit is malfunctioning?
This is also a replacement part being used during the renovation work, specifically for the 30-byte Highline or multifunction steering wheel.
Translated on 29-10-2026, 19:47.
Post16-11-2015, 16:13    Subject: Car won't start, key works? (BKD) Quote
So... I have completed my initial analysis.
You wouldn't have, otherwise you wouldn't have messed with the throttle valve. icon_wink.gif
The initial step would have been to read the posts here and try to understand them...
Please read the tips provided above again!
Translated on 29-10-2026, 19:48.
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Key successfully learned - Radio still active? On-Board Diagnostics (OBD)
No new posts Emergency Mode: High Boost Pressure - Parts Replaced On-Board Diagnostics (OBD)
No new posts Audi A6 Key Programming: Can it work with A8? On-Board Diagnostics (OBD)
No new posts Channel 4 Adapter Not Working? Troubleshooting Guide. On-Board Diagnostics (OBD)
