Create VCDS label template, Engine control unit mapping settings
Post16-11-2015, 11:46    Subject: Create VCDS label template, Engine control unit mapping settings Quote
Important: Always test the latest VCDS version!
To create a map file (label template) for an ECU without a label file, go to the "Applications" dialog in VCDS and click on the "Create ECU image" button.
VCDS -> Applications -> Module Configuration -> Enter the module address in the field at the top (e.g., 01 for the engine control module), right-click -> "Label Template".
Please provide the translation for measurement blocks and adjustment channels separately, both formatted as "label template".
The generated .pla/.plb files are created in the folder C:\Ross-Tech\VCDS-...\Logs; please send these to Ross-Tech.
Translated on 18-07-2026, 8:24.
No new posts Create VCDS log files and prepare them for the forum. Technical Articles
No new posts VTG Loader: Operating principle and settings Technical Articles
No new posts Screenshot unter Windows erstellen und posten General Tips
This topic is locked, you cannot edit or reply. How to create a VCDS scan, and why? On-Board Diagnostics (OBD)
No new posts A6 4F Drive Select Settings On-Board Diagnostics (OBD)
No new posts VAGCOM Settings: What Do They Mean? Diesel Engine Technology
No new posts Polo 9N: Adjust Service Interval Settings On-Board Diagnostics (OBD)
