Climate Change: Urgent Action Needed!
mhernach
Post10-05-2003, 22:29    Subject: Climate Change: Urgent Action Needed! Quote
Hello everyone!!!
I have a Galaxy manufactured in 10/96 with a 1Z engine, and my air conditioning system has stopped working.
I had to replace the refrigerant line from the evaporator to the condenser.
After the air conditioning system was refilled, I heard a whistling sound near the compressor.
I suspect that the air conditioning compressor is still leaking.
Okay, and now my questions...
Has anyone ever had a faulty AC compressor, or something similar? Are there any spare parts available to repair it (other than a new compressor)?
Thank you in advance for your information.
Best regards, Mike.
Translated on 18-09-2026, 8:36.
vikinger
Post11-05-2003, 9:22    Subject: Climate Change: Urgent Action Needed! Quote
Before you replace the compressor, it's best to have the system checked with a tester or a fluorescent dye to identify the source of the problem. Replacing the compressor is very expensive, and a misdiagnosis in this area would be even more frustrating. I haven't heard of a compressor leaking before; it usually just makes noise or loses its pumping capacity. I would suspect a brittle O-ring on a hose line instead.
Translated on 18-09-2026, 8:38.
mhernach
Post12-05-2003, 5:04    Subject: Climate Change: Urgent Action Needed! Quote
Yes, I will definitely do that eventually, but it already has 261,000 km on it, and the performance isn't what it used to be either...
Translated on 18-09-2026, 8:39.
vikinger
Post12-05-2003, 5:06    Subject: Climate Change: Urgent Action Needed! Quote
Aha... well, in that case, that's something different icon_lol.gif.
Varianti
Post14-05-2003, 9:39    Subject: Climate Change: Urgent Action Needed! Quote
Normally, a pressure test is performed before refilling the system. This allows you to check if the system is leak-tight.
mhernach
Post14-05-2003, 9:49    Subject: Climate Change: Urgent Action Needed! Quote
I did that, but the gauge didn't move during the vacuum test. I refilled the AC system since my last post, and there's still refrigerant in it, and it's cooling down to 5°C (41°F) outlet temperature... it just takes a few minutes to get cold.
Translated on 18-09-2026, 8:40.
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B2 CV Joint Leak: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Radiator Leak: Repair Guide & Info Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8L AC Not Working - Repair Guide Electrical Systems, Vehicle Electronics, Multimedia
No new posts Climate leakage due to improper maintenance? Urgent!! Transmission, Chassis, Body & Interior
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts Air conditioning not working - Passat, 1997 Transmission, Chassis, Body & Interior
