On the solenoid for the charging pressure limit, there are 2 hose connections and an electrical connection mounted on top. However, one of the two hose connections (located in the middle of the solenoid) does not have a hose attached?!?!? Can someone tell me if a hose needs to be mounted there and, if so, where it should be directed?
Thank you and best regards.
Thomas Audi A4 Avant 2,0 l TDI (MKB = BRD) Baujahr 01/2007
