P0011 - Camshaft Timing Delayed: Not Reached (Solution)
Karma: +807 / -0   Thank you, like it!
Post01-02-2016, 17:30    Subject: P0011 - Camshaft Timing Delayed: Not Reached Quote
Possible causes for P0011, camshaft timing delayed (bank 2) - actual value not reached:
- Intake camshaft adjuster valve 1 (N205) is defective.
- Fuel pump relay (J17) faulty.
- Incorrect mechanical adjustment (camshaft position), timing chain/belt not in good condition.
Possible solutions:
- Check N205.
- Check J17.
- Check the mechanical initial timing of the camshaft, including the camshaft drive.
Additional information for VAG 4.0l W8 engine: TPL 2010059 (RoW), check the oil filter inside the camshaft adjuster housing.
Ratings - P0011 - Camshaft Timing Delayed: Not Reached
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Fails to Meet Lending Target Diesel Engine Technology
No new posts Injection Volume Not Reached: Troubleshooting On-Board Diagnostics (OBD)
No new posts Golf IV ATD PD - Unable to reach top speed - LOG Upload
No new posts AGR Not Closing: LMM Value Never Reaches Target Diesel Engine Technology
