P1000 - OBD2 System Test Incomplete (Solution)
Karma: +807 / -0   Thank you, like it!
Post02-02-2016, 10:38    Subject: P1000 - OBD2 System Test Incomplete Quote
The error code P1000, OBD2 System test incomplete, indicates that the Readiness Test (OBD2 self-test) is either still in progress (e.g., not completed after a repair) or cannot be completed (due to a malfunction in the exhaust gas cleaning/AGR/SCR system).
Ratings - P1000 - OBD2 System Test Incomplete
No new posts OBD2 Adapter: MFA via OBD2 Diesel Engine Technology
No new posts ABS/ESP Test: Air in Brake System Won't Go Away On-Board Diagnostics (OBD)
No new posts OBD2 adapter Diesel Engine Technology
No new posts OBD2 Diagnostic Adapters: Buy Now! On-Board Diagnostics (OBD)
