P2303 - Ignition Coil B, Primary Circuit: Signal too low (Solution)
Post03-02-2016, 10:59    Subject: P2303 - Ignition Coil B, Primary Circuit: Signal too low Quote
Error code P2303 describes a problem in the circuit between the control unit and the ignition coil. It is necessary to check the electrical wiring and the ignition coil (short circuit to the primary winding).
Ratings - P2303 - Ignition Coil B, Primary Circuit: Signal too low
No new posts Low rail pressure, 3.0 CR-TDI General Tips
No new posts Fuel pressure too low (P0087) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4: Ignition Coil Failure, Then Intake Manifold Issue On-Board Diagnostics (OBD)
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts C2 catalyst conversion rate too low Gasoline Engine Technology
No new posts Low Smoke Suppression: Causes & Solutions On-Board Diagnostics (OBD)
