Read particulate filter loading status
vag-driver
Post18-04-2016, 15:21    Subject: Read particulate filter loading status Quote
I read the technical article "Forced regeneration of particulate filters in VAG TDIs using VCDS" and, as a result, I wanted to find out the loading level of the particulate filter in a Sharan 7N.
I'm only getting "n.v." displayed for MWB 108.
VG
Andreas.
Karma: +805 / -0   Thank you, like it!
Post18-04-2016, 16:44    Subject: Read particulate filter loading status Quote
Especially the point "Forced DPF regeneration 1.4l/1.9l/2.0l/2.5l PD TDI".
Where's your diagnostic scan tool, or are we supposed to guess what's wrong with the engine? I'm guessing it's a PD-TDI.
vag-driver
Post18-04-2016, 16:57    Subject: Read particulate filter loading status Quote
Hello Rainer,
Sharan 7N with PD?
It's a 2.0 CR engine with 170 horsepower. That's why I went directly to the 2.0 CR section.
VG
Andreas.
Post18-04-2016, 18:37    Subject: Read particulate filter loading status Quote
You can find the value for oil ash content in the 300 range, or use the search function at the top and type in "oil ash" or "DPF." A value of 0.17 indicates that it is considered full. The quantity refers to "au l", so the maximum amount is 175ml.
A car scan like this can always be helpful. You're probably talking about a CFG(B).
Post18-04-2016, 18:38    Subject: Read particulate filter loading status Quote
"Your engine might be too new; I've updated the article accordingly."
PS: Thank you very much for the hint! icon_smile.gif
Post18-04-2016, 18:40    Subject: Read particulate filter loading status Quote
Should be max. It should be from the year 2012, after which the 170 model was no longer produced.
vag-driver
Post18-04-2016, 18:56    Subject: Read particulate filter loading status Quote
vag-driver
Post18-04-2016, 19:02    Subject: Read particulate filter loading status Quote
0.06l icon_lol.gif at 97,000 km.
@Rainer
It is the value 377.
Post18-04-2016, 19:13    Subject: Read particulate filter loading status Quote
It's a CFGB... the last letter makes the difference in this case. It was replaced by the CFGC at the end of 2012 and, after the "extensive" facelift (and Euro6 compliance), by the CUWA. Interestingly, all of these engine codes do not have AdBlue exhaust aftertreatment in the Sharan, Tiguan, or Passat (although I'm not entirely sure about the CUWA). Therefore, the DPF (Diesel Particulate Filter), and the pipe that follows it with its flexible section, looks different than it does in the platform brother (referring to a similar vehicle model).
vag-driver
Post18-04-2016, 19:25    Subject: Read particulate filter loading status Quote
I don't understand Volkswagen's model policy. "All Sharan models have AdBlue, while other models do not."
"What does that mean?"
a) In other cases, they have managed to obtain the required measurement values without using SCR.
b) In the case of the Sharan, they went directly to modern exhaust treatment technology, perhaps because they wouldn't have been able to achieve the required emission levels otherwise?
Post18-04-2016, 20:44    Subject: Read particulate filter loading status Quote
Well, you don't have it like that either, do you?
The Sharan is simply much heavier and larger. In my opinion, the only thing that's surprising is that it's the same MKB [presumably referring to a person or entity].
No new posts Particulate Filter (DPF) VAG TDI Diesel Mass Balance, Max... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Forced DPF Regeneration: VAG TDI with VCDS Troubleshooting & Guides
No new posts Touran: Read DPF Ash Mass with VCDS (BLS) Diesel Engine Technology
No new posts RPF Load Status MWB 068 On-Board Diagnostics (OBD)
No new posts DPF: 2.7/3.0 TDI Diesel Particulate Filter On-Board Diagnostics (OBD)
No new posts New particulate filter Diesel Engine Technology
