VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment
georgmech
Post24-02-2016, 19:02    Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment Quote
Hello, can anyone help me? I have a GOLF 5 1.4 BAD and I need to replace the crankshaft seal. Can I install the magnetic ring without special tools, and if so, how?
Wir sind eine Werkstatt in Langenrohr bei Tulln und kämpfen täglich mit Fahrzeugproblemen. Wir sind sehr dankbar das es dieses Forum gibt , denn man kann nicht alles wissen, aber man kann sein Wissen weitergeben am Ende haben alle was davon
Back to top Profile PM Email
Post25-02-2016, 12:44    Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment Quote
As far as I can tell, this won't work without special tools.
You need the "T10134" and the corresponding instructions for it. Everything else was a matter of chance.
I would try to borrow the tool from icon_lol.gif.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post25-02-2016, 14:38    Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment Quote
Hello Georg,
In this YouTube video, it is explained (Elring) how it is mounted.
Without that, it's not possible. What else might be needed, the measuring tool for the crankshaft belt pulley (to fix the OT point)?
What is not explained here:
the "Red" pin which is inserted just before assembly is for gasoline engines , the "black" is for diesel engines !
georgmech
Post26-02-2016, 16:05    Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment Quote
It's getting stranger. If I disconnect the sensor, the engine runs perfectly normally. I borrowed the original VW tools and installed the ring according to the VW instructions. Since then, I've been getting intermittent error messages for the camshaft and crankshaft sensor, out of range. Motor was on OT and disconnected, it's like we say in Austria, "to be a fool"
Post26-02-2016, 17:03    Subject: VW GOLF 5 BUD Magnetic Sensor Crankshaft Sensor Adjustment Quote
....The engine was, however, on and disconnected
Also, the correct marking spike should also be used with the special tool?
The fact that it operates with a defined input, likely stems from the fact that the NW (noise) signal is used as a substitute.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Crankshaft Sensor 1Z Diesel Engine Technology
No new posts Same error code despite new crankshaft sensor?! Diesel Engine Technology
No new posts VW Golf PD, 150 hp, first registration 03/01 Diesel Engine Technology
No new posts Golf TDI PD: Fuel Consumption Data Diesel Engine Technology
