P1118 - Oxygen Sensor Heater Circuit Malfunction (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Karma: +796 / -0   Thank you, like it!
Post26-04-2016, 15:11    Subject: P1118 - Oxygen Sensor Heater Circuit Malfunction Quote
Error code 17526/P1118/004376 - Heating lambda sensor (oxygen sensor), open circuit.
Possible symptoms:
- The MIL (Malfunction Indicator Lamp) light is illuminated on the instrument cluster.
- Increased fuel consumption.
Possible causes:
- Incorrect wiring to the lambda sensor.
- Faulty lambda sensor (oxygen sensor).
See also:
Okay, I'm ready. Please provide the German text you want me to translate into English. Just paste it here, and I will give you the translation.
Translated on 13-07-2026, 2:42.
Ratings - P1118 - Oxygen Sensor Heater Circuit Malfunction
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P2100 - Drosselklappenmotor, Fehler im Stromkreis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0046 - Turbocharger Boost Control Circuit Malfunction, M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. offener luftfilter!?!? Diesel Engine Technology
No new posts TDII open-air filter and its effects!!! Diesel Engine Technology
No new posts Radnaben warm trotz offener Bremsen Transmission, Chassis, Body & Interior
No new posts Gear oil is not draining even though the drain screw is o... Transmission, Chassis, Body & Interior
