RPM display for TDI engine
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Boro
Post08-11-2006, 12:52    Subject: RPM display for TDI engine Quote
I installed a TRW speedometer in my Ibiza because the original one showed over 300,000 km. Now I'm having a problem: it's not displaying the RPM correctly. I wasn't aware that this could happen. If you use the 'hidden' menu, the correct RPM is displayed. Does anyone have any idea what might be causing this???
It's a TDI instrument cluster, so it's not a gasoline engine issue! The mileage, MFA (Multi Function Display), everything else is the same, and everything else is working fine! The idle speed is 920 rpm, but the display shows 750 rpm. At 3000 rpm, the display shows approximately 2300 rpm?!
Best, Boro.
Boro
Post19-11-2006, 13:46    Subject: RPM display for TDI engine Quote
After checking everything and installing different data sets on my speedometer, the tachometer works correctly with some, but always shows a lower RPM with others. It seems that different hexadecimal numbers are used for the calculation depending on the data set. Unfortunately, the devices that operate at the correct speed do not have the MFA function, so I cannot use it.
'So, is it possible to manipulate the signal sent to the instrument cluster in a way that it displays the correct value? Would adding a resistor be too much? But what do I do if the signal is too low?' Does anyone have any ideas?
No new posts Drehzahlanzeige i. Tacho Polo 6N Diesel 1998 mit 1.9 TDI AFN Electrical Systems, Vehicle Electronics, Multimedia
No new posts Golf IV Tacho gegen Tacho mit FIS tauschen Transmission, Chassis, Body & Interior
No new posts Tacho: Wegimpulszahlanpassung G3 Diesel Engine Technology
No new posts A4 Tacho (KI) Austausch ? On-Board Diagnostics (OBD)
