Torrn
22-05-2018, 8:11 Subject: A4 B6 2.5 TDI Fuel Injector Pump Failure |
Okay, here's the translation:
"Hey everyone, I'm having a problem with my Audi. It's not running properly anymore. I suspect the fuel injection pump is broken. What do you think?" It's an A4 2.5 TDI with a build motor.
But in the measurement data blocks, you can see if the pump is defective, right? And if there are many zeros, does that mean it's working properly???
| Description: |
| File size: |
6.83 MB |
| Viewed: |
2077 times |
Translated on 06-09-2026, 6:22.
Joined: 04/12/2002 Posts: 18132 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
22-05-2018, 20:07 Subject: A4 B6 2.5 TDI Fuel Injector Pump Failure |
First, check the most obvious things: whether the fuel injection pump is receiving enough fuel and whether it's drawing in any air bubbles. Then, check the timing of the belt drive, specifically the drive for the electronic stability program (ESP).
Translated on 06-09-2026, 6:23.
Profile PM WWW Garage |
