Broken AC: Troubleshooting & Repair Tips
Go to page: 1, 2  Next
Basti1605
Post08-06-2016, 10:43    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Hello everyone,
My brother owns a Skoda Octavia 1Z, manufactured in 2013, with engine code CFHC. Recently, the air conditioning system has stopped working. I performed an AC service on the vehicle to check if there was enough refrigerant in the system. The result: everything seems fine so far. The system is not leaking.
There is also voltage present at the climate compressor, as well as at the pressure switch. If I unplug the pressure switch, the fans start running. Is this normal? Now my question: Is the compressor defective? Based on my assessment, everything points to that...
Do you have any more suggestions on what else I can check?
I am very grateful for any suggestions.
Translated on 24-08-2026, 20:38.
Karma: +807 / -0   Thank you, like it!
Basti1605 likes this.
Post08-06-2016, 11:29    Subject: Broken AC: Troubleshooting & Repair Tips Quote
With VCDS, the reason for the air conditioning system being deactivated can be identified.
See also:
Translated on 24-08-2026, 20:40.
Basti1605
Post08-06-2016, 12:06    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Hello Rainer,
Thank you for your reply. Unfortunately, I don't have access to VCDS, but we do have an AVL tester.
Could you tell me which menu item (MWB) I need to go to in order to view various "as-is" conditions? Is there an overview of the menu items? Are they the same for everyone?
Here's what else I can tell you about the compressor: The pulley is rusty brown, and the middle screw (Torx size 30) seems stuck; I can neither tighten it nor loosen it. It looks like a portion of it might be protruding.
Translated on 24-08-2026, 20:41.
Karma: +442 / -0   Thank you, like it!
Post08-06-2016, 12:13    Subject: Non-working AC: Troubleshooting & Repair Tips Quote
Basti1605 wrote:
There is also voltage present at the climate compressor.
Did you measure it under load (i.e., with the compressor attached)?
Have you ever looked at the pulley? Does the inner part rotate, or is it stationary?
Greetings.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 24-08-2026, 20:42.
Basti1605
Post08-06-2016, 12:18    Subject: Non-Working AC: Troubleshooting & Repair Tips Quote
guste100 wrote:
Basti1605 wrote:
There is also voltage on the climate compressor.
Did you measure them with load (i.e., with the compressor attached)?
No, only when the plug is disconnected.
As mentioned above, the pulley is rusty. However, it still rotates. I have a picture of it, but I can't upload it.
Best regards, Basti.
Translated on 24-08-2026, 20:43.
vag-driver
Post13-06-2016, 13:27    Subject: Broken AC: Troubleshooting & Repair Tips Quote
You probably also have a compressor with a driven disk. Check to see if it might have been triggered. There's a picture in my thread, which Rainer linked, showing what it looks like.
"VG" translates to "Very Good" in English.
Andreas.
Translated on 24-08-2026, 20:45.
Basti1605
Post13-06-2016, 18:22    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Hello Andreas,
I now have a new compressor and will install it sometime this week. However, I have to wait until the flushing machine arrives at our company.
Here's what would be helpful for me to know: How can I tell from the outside whether a compressor is permanently powered or if it's a "regular" one?
What pressure levels should I expect? In other words, what pressure is likely at different times?
Thank you for your support!
Basti.
 Antrieb Kompressor der Klimaanlage
 File size:  1.38 MB
 Viewed:  2258 times
Translated on 24-08-2026, 20:46.
vag-driver
Post13-06-2016, 20:29    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Hello Basti,
The friction disc appears to be intact. icon_rolleyes.gif However, I'm surprised that the screw on the shaft is protruding.
You have a compressor that is continuously running. The cooling capacity of the compressor is controlled via a control valve.
Before you replace the compressor based on suspicion, I would recommend conducting a thorough analysis first. In the worst-case scenario, something else is faulty, and you'll have to evacuate the system again.
Therefore, it would be beneficial to examine the compressor's measurement data blocks and shutdown conditions.
Good luck!
Andreas.
Translated on 24-08-2026, 20:47.
Basti1605
Post13-06-2016, 21:10    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Hello Andreas,
Which blocks should I focus on then?
As I mentioned earlier, I currently only have access to an AVL tester (which also displays the mean effective pressure), but I intend to purchase a VCDS for personal use.
I'm also surprised about the middle screw. Especially since it's not possible to tighten or loosen it.
Voltage is applied to the compressor and the pressure switch.
I really want to expand my knowledge about debugging climate models now.
Thank you for your help.
Basti.
Translated on 24-08-2026, 20:49.
brezelmann01
Post13-06-2016, 21:18    Subject: Broken AC: Troubleshooting & Repair Tips Quote
If the system is actually filled as described above, I would simply apply 12V directly to the control valve and start the motor for a quick test without any diagnostics.
Either the cold air/refrigerant line at the expansion valve becomes cold within 1 minute, or everything remains warm -> replace the compressor and/or control valve.
Translated on 24-08-2026, 20:50.
vag-driver
Post13-06-2016, 21:20    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Hello Basti,
It is important that:
- Error memory
- Compressor current
- Compressor load
- any existing shutdown conditions.
- Carefully check the pipe with your hand to see if it's cold, in order to rule out a faulty expansion valve/throttle.
Andreas.
Translated on 24-08-2026, 20:51.
Basti1605
dieselschrauber likes this.
Post23-06-2016, 13:37    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Hello colleagues,
Today was the day. I investigated the air conditioning unit. It turned out to be 100% the compressor. I did some more research and found that there are two common problems with this type of compressor. Either the three pins on the front of the drive plate break off (a designed weak point in case of overload), or, as in my case, if the center screw comes loose, the shaft inside the compressor shears off. This results in a loss of power transmission.
I would also take the compressor apart to examine it and see how it works inside. If you'd like, I can post some pictures!
So, the compressor is new, the condenser is new, and everything is working fine again.
I would like to express my sincere gratitude for your assistance and the numerous helpful suggestions you provided.
Basti.
Translated on 24-08-2026, 20:53.
Post23-06-2016, 14:24    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Thank you for the feedback! Pictures of the inside of the compressor would be great.
Translated on 24-08-2026, 20:54.
vag-driver
Post23-06-2016, 19:57    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Why did you replace the capacitor? Or were you referring to the dryer?
Andreas.
Translated on 24-08-2026, 20:55.
Basti1605
Post24-06-2016, 17:17    Subject: Broken AC: Troubleshooting & Repair Tips Quote
I replaced the condenser including the dryer (which was not a separate part that could be replaced on that model) because the vehicle had started losing refrigerant again since the last AC check. And I didn't want to start taking everything apart again in a few days icon_smile.gif.
I haven't disassembled the compressor yet, but I will definitely post pictures soon.
Basti.
Translated on 24-08-2026, 20:56.
vag-driver
Post25-06-2016, 16:11    Subject: Broken AC: Troubleshooting & Repair Tips Quote
Basti1605 wrote:
... (which could not be individually replaced in that model)...
VAG is just getting worse and worse. icon_cool.gif It's only a matter of time before you can't even buy motor oil anymore, and the entire engine will have to be replaced.
Andreas
Translated on 24-08-2026, 20:57.
No new posts A3 8P1 AC Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Van AC Repair: 7-Seater, No Cooling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J AC Repair: No Cooling - 2000 Model Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Manual AC Not Working? Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Tiguan 5N air conditioning system not working Transmission, Chassis, Body & Interior
No new posts Audi A3 AC Not Working: 8P BKD Repair Guide Transmission, Chassis, Body & Interior
No new posts ESP Failure: Causes and Solutions On-Board Diagnostics (OBD)
